Im a major noob to wheels guys im upgrading to a series 3 R33 GTR soon and CBF reading through the 107 pages lol :yes: but basically the below link are the rims im looking to buy im after these in 18x10 - 10.5" if i can get them just wondering if anybody can tell me what offset i would need to get 275-285s under the ass without stupid camber or rolling guards etc they also need to clear my alcon brakes which are 315mm rear rotors and 4 spot calipers and and fronts are 356mm rotors with BIG 4 spot calipers im after diiiiiiiish also :whistling: Is this possible?
Cheers fellas
http://www.ebay.com.au/itm/170906816446?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
A little help anybody??? Please.........
dont lower the car on anything you are likely to bend/kink the guard...
if you were close id help you out on sunday as i have a guard roller as well as all the other gear
yeh, you have to be real careful with that method... if it's just to lip the guards you can manage it without distorting them
Cheers fellas
http://www.ebay.com....984.m1423.l2649
this one slipped through
nice wheels however it doesnt state what offset they are selling.....you would want to run an 18x10 (offset in the high teens) and you should be fine with that tyre size
I split the paint a tiny bit.
Was only able to get half a guard done and it was pretty hard I was unable to get the lip flush with the guard.
Rather the clogging up the offset thread if someone who knows what to do could message me that would be great either on here or mobile is 0408 257 613
Based on what exactly?
Kasko it's going to look tits brah :yes:
Based on another 33gtst with 9+20 all round. Front was little poke, rears were a little inset. That is why I went 10+30 on rears for that extra little poke..
Don't get me wrong, still looks mean, if you want same size all round - that offset would be the go.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
