a little stretch is good as there is less flex in the sidewall and you get better response from the tire. You have ordered the 235 already so just run with it....worse comes to worse replace when you are due for a new set with 255s
Yeah, i agree. The difference it makes is not worth the price but as you said, if and when i need to replace them, i'll go for the 255's. I am confident that 18x10 +20 rims with 255/40 tyres would fit on the rear however, i am not actually 100% sure so probably best to be safe than sorry.
Thanx for your help.
Found out they are 19x10+17
Trial fitting tomorrow then choosing the tyre size. Bloke reckons prob 265 max on there.
Will put up pics when fitted. Fingers crossed. Definately going to fill the guards. lol
Pic of rims fitted. 19x 10 +17 255 tyres
No heights have been set up for track/curcuit and car counter wieghted each courner so low enough. Plus tyres hang out past the guards. Dont want to camber them as i will loss traction when car launchs.
More photos of my car.
Width: 9.5inch
Offset: 22+
Tires: 235/40/18 (the 40 could be wrong I cant recall it)
The backs could do with a spacer to add a little poke.
Currently has a fair bit of camber which I dont like.
Will get that fixed asap
Width: 9.5inch
Offset: 22+
I don't mean to alarm you but the stig is behind you..
what would fit nicer out of 18x9.5+12 and 18x9.75+20 on a r33 gtst?
interesting question however depends on what you want to achieve here. Couple of things below
  • Rims are virtually the same size only mm's (roughly 3mm wider each side) in it!
  • The +12 is still going to have more poke (towards the guard) by roughly 5mm of or so
  • what tyre size do you want to run? Again as its only 5mm give or take overall not much difference
hope that helps you a touch
Ok just picked up a cheap set of rims, not as good as some on here but there better than the standard ones on there now.
What will I need to do to get them to fit, just guard rolling?
Front 19x8 235/35
Rear 19x9.5 275/30
Sorry for my knob question but wont to know what im getting myself into this weekend when I try and fit them.
Thanks
what are the offsets? judging by the photo id say pretty high +30s low 40s?? my guess is not much at all maybe slightly roll the inner guard lip on the rear due to tyre size but should be a breeze
Edited by Frosty
yeah from what i worked out i dont think there is much in it at all,
was hoping to run a 215 40 or 45 or would i be better going a 225 35?
the reason i ask is the rims only come in 9.75+20 so was hoping itl fit with some poke
yeah all those tyre sizes will be fine on that offset! see post #2208 with 235/40/18 tyres on R33 will give you an idea :D
Front 19x8 235/35
Rear 19x9.5 275/30
Thanks
Just put the rims on only just fit, will be rolling the guards.
Question, how close are everyones tyres to the struts, looks a little to close???
Will 265 help that much??/
offset 40+
Thanks
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
