a little stretch is good as there is less flex in the sidewall and you get better response from the tire. You have ordered the 235 already so just run with it....worse comes to worse replace when you are due for a new set with 255s
Yeah, i agree. The difference it makes is not worth the price but as you said, if and when i need to replace them, i'll go for the 255's. I am confident that 18x10 +20 rims with 255/40 tyres would fit on the rear however, i am not actually 100% sure so probably best to be safe than sorry.
Thanx for your help.
Found out they are 19x10+17
Trial fitting tomorrow then choosing the tyre size. Bloke reckons prob 265 max on there.
Will put up pics when fitted. Fingers crossed. Definately going to fill the guards. lol
Pic of rims fitted. 19x 10 +17 255 tyres
No heights have been set up for track/curcuit and car counter wieghted each courner so low enough. Plus tyres hang out past the guards. Dont want to camber them as i will loss traction when car launchs.
More photos of my car.
Width: 9.5inch
Offset: 22+
Tires: 235/40/18 (the 40 could be wrong I cant recall it)
The backs could do with a spacer to add a little poke.
Currently has a fair bit of camber which I dont like.
Will get that fixed asap
Width: 9.5inch
Offset: 22+
I don't mean to alarm you but the stig is behind you..
what would fit nicer out of 18x9.5+12 and 18x9.75+20 on a r33 gtst?
interesting question however depends on what you want to achieve here. Couple of things below
  • Rims are virtually the same size only mm's (roughly 3mm wider each side) in it!
  • The +12 is still going to have more poke (towards the guard) by roughly 5mm of or so
  • what tyre size do you want to run? Again as its only 5mm give or take overall not much difference
hope that helps you a touch
Ok just picked up a cheap set of rims, not as good as some on here but there better than the standard ones on there now.
What will I need to do to get them to fit, just guard rolling?
Front 19x8 235/35
Rear 19x9.5 275/30
Sorry for my knob question but wont to know what im getting myself into this weekend when I try and fit them.
Thanks
what are the offsets? judging by the photo id say pretty high +30s low 40s?? my guess is not much at all maybe slightly roll the inner guard lip on the rear due to tyre size but should be a breeze
Edited by Frosty
yeah from what i worked out i dont think there is much in it at all,
was hoping to run a 215 40 or 45 or would i be better going a 225 35?
the reason i ask is the rims only come in 9.75+20 so was hoping itl fit with some poke
yeah all those tyre sizes will be fine on that offset! see post #2208 with 235/40/18 tyres on R33 will give you an idea :D
Front 19x8 235/35
Rear 19x9.5 275/30
Thanks
Just put the rims on only just fit, will be rolling the guards.
Question, how close are everyones tyres to the struts, looks a little to close???
Will 265 help that much??/
offset 40+
Thanks
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
