they will sit more "in" and look better if the car is lowered more
could probably go a 235 as well, what are you running? 255?
not trying to nit-pick, it looks good, but with the specs you have it could look seriously awesome :)
If your referring to my wheels they're a 235/40 federal rsr which im led to believe is wider than some other tyres in the same specs. I will be lowering it a fraction more though :thumbsup:
wow the RSR's really are wide!
will look better once lower and it tucks in a little more
R33 GTST
Work XD9
18x9 +30 - Federal 595 235/40
18x10 +38 - Federal 595 265/35
Certainly fills the guards better than previous wheels I had, but not as close to the lip as I'd hoped. Probably could fit another 10mm poke on each corner without any drama. I had all the guards rolled in preparation, but in hindsight, probably not needed.
I reckon these offsets in the XD9s are good if you're looking for minimal hassle in fitment, but definitely not as tough as f +20 / r +18 (which most guys have).
At least I have an excuse to start saving for a set of Meister S1Rs ;)
post-83859-0-58563600-1359588675_thumb.jpg post-83859-0-60056600-1359588844_thumb.jpgpost-83859-0-60495300-1359588860_thumb.jpg
  • Like 1
nope... I had some on custom order from work in the sizes i metioned above in satin black and after 4 months they hadn't even started them so I wint with rays instead
hi guys,, im sorry if ive missed the sticky/pinned link ,,
im wondering if any1 knows of a " Virtual Wheel Visualizer/Selector " which does have the R32 details/specs ??
the US sites dont show cirtain models
thanks guys
What offset do ya recon if I were to order new rota grids
Maby
18x9 +30 f
18x10 +38 r
235/35
Makes about 30mm further out than stock.
Too soft? :P
Daily driver 500km per week so I can do a little camber bit don't want much, just a little for flush fitment
Edited by GH05T
18x10+35, 18x9.5 +35 or
18x8.5+30.
These are available in white rota grids locally, and cheap...
For a set of wheels w Achilles Sport Tyres fitted and balanced.
$1658 in total brand new.
Recon it will work quite well, hoping to get the coilovers in and get round their to test fit.
thanks guys
not that i know off
what information are you after or just looking to try different rims and what they look like on your car?
Maby
18x9 +30 f
18x10 +38 r
235/35
Too soft? :P
what car?
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
