has anyone fitted R33 GTR rims to an R34 GTR??? How would they sit in the gaurds???
Chasing some 17's so I can get an bit of tyre flex on the strip, can anyone suggest any 33gtr altenitives ???
Today I fitted my brand new enkei 18x9.5+12 with new advan 245/45/18, and on the left front wheel it scrapes with the rear of the arch when turning slowly? am I going have to get new tires with smaller profiles???
you could:
  • live with it
  • roll guards
  • camber
  • buy smaller profiled tyres
  • raise it
personally I'd buy some 235/40/18's
It only catches the side skirts front connection plate that comes into the wheel arch..... so annoying, I removed it becasue it was pulling it off tearing the plastic. Rarrrrrrh
the guard liner?
if you are hitting that it's a good idea to lip the guards just enough so they dont catch the tyre ever and tear the guard in half
(like blags lol)
the guard liner?
(like blags lol)
not the guard liner, on my r32 gtr the front of the side skirt actually comes around into the wheel arch and theres 2 screws,
Was thinking that but am unsure what + I need. Think it is around +20 to sit nicely in the guards of a 34 GTR
im so happy with these matte black rpfs, and for unsprung weight reasons aswell, there super light, only 7kgs!!!!! Forged BBS LMS which are forged are 12kgs in the same size!
bend and remove.... bend and remove ;)
pic?
I'm thinking of a set of matte black RPF01 in 18 x 9.5 +12 for the evo
Hey guys,
Was looking at getting some: Rota GRIDR 18 x 9.5, 5x114.3, +20 Absolute Green
To put on my '99 R34 GTT, It's currently lowered with stocks wheels still on it, doesn't have a camber kit as far as I'm aware. Anyone know how hard/easy it will be to get these to fit? Camber kit or rolling guards should be fine? Or just spend the money now and get a camber kit right away.
Cheers, Zac
Hey guys,
Cheers, Zac
Those rims will fit but you will need to roll guards n do some liner work.
Otherwise it all also depends on how much camber you do end up running as well as tyre size.
As far as camber kits go, they are only needed to reduce camber after lowering the car (essentially you can have heaps of camber from the stock arms if ur car is lowered, it is getting less than 1-1.5 degrees that is the problem once it is lowered). Obviously this isnt going to help the rims fitting as taking camber out puts the tyres closer to the wheel arch that is the limiting factor in actually fitting big rims with lower offset.
Any suggestion for tyre size? Its daily driven for now. So pretty much i'd just be looking at rolling the guards abit and giving it abit more camber, i love camber but don't want huge amounts as its daily driven,
stretch is against my religion. But a 235 should see you right.
Otherwise camber is also a bad thing in a street driven daily unless you dont mind paying the $ that it costs in how much quicker you chew ur tyres out because of said camber.. but around 1 degree on the rear should see the rims n tyres fitting as well as minimal tyre wear from it.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
