How much work required to fit 18x10+38 Work XD9s to the rear of a 32 GTSt?
Ive seen some older pictures on this forum of a guy running them but dont know how much drama there is involved fitting them up, pics dont look like theres much camber or poke..
Car is just gonna be used as a weekend toy (or even a couple times a month) so my care factor for legality is exactly zero.
Sooo many posts and couldn't find what I was looking for without dying...
Looking at putting Lenso D1Rs on my R33 gtst. What would be the best size and offset with out too much guard work (Rolled guards at the most)? Prefer 18inch wheels and must be able to hold 300rwkw decently.
Cheers
Buying a set of wheels for autocross in the US, looking based solely on what tires I can fit and offset etc not looks because of this.
It's a R32 GTS-t, I want to fit 235/45/17 in front and 255/45/17 in rear. If it can be done without rolling fenders it would be a bonus, but i'm not against doing that.
Most of the people fitting tires like that seem to have LMGT2 (+35 front +38 rear on 17x8/x17x9) and fit 255/40 in rear and i'm looking to see if there is an offset that would be better.
Trying to fit max tire within reason for this. Not looking to pull fenders or modify them aside from rolling.
Hey gots i just recently bought a set if rims for my r33 gtst they are 17x9 +35 allround now the rears fit perfectly but the fronts Rub on the control arm what and it was recomended that these rims would fit anyone know if these rims should fit the front ?? Thanks
Strange... The 34 is similar in the front as far as i know and i run a 18x9 +30 with a 265 tyre and it clears...
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
