How much work required to fit 18x10+38 Work XD9s to the rear of a 32 GTSt?
Ive seen some older pictures on this forum of a guy running them but dont know how much drama there is involved fitting them up, pics dont look like theres much camber or poke..
Car is just gonna be used as a weekend toy (or even a couple times a month) so my care factor for legality is exactly zero.
Sooo many posts and couldn't find what I was looking for without dying...
Looking at putting Lenso D1Rs on my R33 gtst. What would be the best size and offset with out too much guard work (Rolled guards at the most)? Prefer 18inch wheels and must be able to hold 300rwkw decently.
Cheers
Buying a set of wheels for autocross in the US, looking based solely on what tires I can fit and offset etc not looks because of this.
It's a R32 GTS-t, I want to fit 235/45/17 in front and 255/45/17 in rear. If it can be done without rolling fenders it would be a bonus, but i'm not against doing that.
Most of the people fitting tires like that seem to have LMGT2 (+35 front +38 rear on 17x8/x17x9) and fit 255/40 in rear and i'm looking to see if there is an offset that would be better.
Trying to fit max tire within reason for this. Not looking to pull fenders or modify them aside from rolling.
Hey gots i just recently bought a set if rims for my r33 gtst they are 17x9 +35 allround now the rears fit perfectly but the fronts Rub on the control arm what and it was recomended that these rims would fit anyone know if these rims should fit the front ?? Thanks
Strange... The 34 is similar in the front as far as i know and i run a 18x9 +30 with a 265 tyre and it clears...
    • Thanks for the linkie. Certainly always a great deal of help when people post comparisons like these, but I think for now I'll stay away from any semi slicks. I did go ahead and order the sportcontact 7. My buddy has them on his modified A4 and he keeps saying how good they are. For my intended purposes these will probably work real well. I'll report on them once I had the chance to try them out
    • Talk about noisy. Even when I still had the Tomei under the car I could distinctly hear the tires rolling. And I doubt I ever will need maximum grip like on a track. My GTR will maybe never even see the 600hp mark and I need to get used to the car quite a bit before challenging the limits of its handling. For the next winter storage I think I will get a set of these rubber drive-on thingies that have a tire shaped base. Those supposedly really help prevent flat spots.
    • Well our climate is definitely way less hot overall and the weather can be quite picky at times. I just know that during normal road use or even spirited drives there is no way I'd be able to consistently stay in the operating temperature, and constantly changing the tire pressure would also be a royal pain.
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
