How much work required to fit 18x10+38 Work XD9s to the rear of a 32 GTSt?
Ive seen some older pictures on this forum of a guy running them but dont know how much drama there is involved fitting them up, pics dont look like theres much camber or poke..
Car is just gonna be used as a weekend toy (or even a couple times a month) so my care factor for legality is exactly zero.
Sooo many posts and couldn't find what I was looking for without dying...
Looking at putting Lenso D1Rs on my R33 gtst. What would be the best size and offset with out too much guard work (Rolled guards at the most)? Prefer 18inch wheels and must be able to hold 300rwkw decently.
Cheers
Buying a set of wheels for autocross in the US, looking based solely on what tires I can fit and offset etc not looks because of this.
It's a R32 GTS-t, I want to fit 235/45/17 in front and 255/45/17 in rear. If it can be done without rolling fenders it would be a bonus, but i'm not against doing that.
Most of the people fitting tires like that seem to have LMGT2 (+35 front +38 rear on 17x8/x17x9) and fit 255/40 in rear and i'm looking to see if there is an offset that would be better.
Trying to fit max tire within reason for this. Not looking to pull fenders or modify them aside from rolling.
Hey gots i just recently bought a set if rims for my r33 gtst they are 17x9 +35 allround now the rears fit perfectly but the fronts Rub on the control arm what and it was recomended that these rims would fit anyone know if these rims should fit the front ?? Thanks
Strange... The 34 is similar in the front as far as i know and i run a 18x9 +30 with a 265 tyre and it clears...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
