Will I need any mods or spacers or guard rolling ????
Skyline model = r34 GTT
Wheel diameter = 17"
Wheel width = 9.5"
Wheel offset = +12
Tyre size = ?
Modifications to fit = ?
Stop being a moron. Go back 1 page, and look. Oh wow there is 9.5+20 there, ON AN R34! Oh and he has written the mods to fit!! It's almost like this thread is full of information or something.
Skyline Model = R32 GTST
Wheel Diameter = 18"
Wheel Width = 9.5 Fronts 10 Rears
Wheel Offset = +18 Fronts +15 Rears
Tyre Size = 235/40 Fronts 265/35 Rears
Modifications to fit = 20mm wide front guards 30mm wide rear guards
Fronts = 2.5deg neg camber
Rears = 1.5degs neg camber
Any many many hours fiberglassing
Is lowered cant figure out how to upload photos. everytime I use the photo/link button above and copy a link across from photobucket is freezes -.-
Edited by Cxxo
If you go into the "more reply options" you can upload and attatch, rather than linking via a site.
HI Guys, getting new tyres soon for my R34GTR.
I have Advan 18x10 +25 rims and they do not have the tyres I want in a 275x40 18 , but they have a 285x30 18 , would they fit without scrubbing.
I just went thru every page of this thread :)
I did have 19x9.5+25 with 245s and no mods were required...they are now sold i want jap wheels.
now im tossing up between the following for my r32 gtr:
1). 18x9.5+22 with 265s ('safe' option with gauranteed clearance on full lock & guards)
OR
2). 18x10+20 with 265s (will work with with no mods if i run nitto invo tyres, thx SIR-RB for the advice)
decisions decisions...also looking for other ppls opinions :)
Ok thx for the feedback :)
Would it be optimistic of me to think I can run 265s on 10s without guard rolling or is this simply required from your personal experience?
Where did it rub on your inner guards, on the front which sits directly behind the bumper bar right? What tyre brand are u running?
I rolled the guards myself (on the rear). Previous tyres bashed the lip out on the front guards lol. Rolling is required unless you car is high. It'll probably still scrub.
Yep the front part, because I used to run a bit more caster. Had to dial some caster back and add negative camber up front (around -2deg, -1.5deg rear). Caster is around the 5deg mark.
I'm running Falken FK452 at the moment. Previously had old Bridgestone TS-02 or something with more rounded shoulders so didn't need guard rolling.
If you're worried about not rolling, then get 9" and run 255 wide tyres. I would rather roll and try to cram the widest tyre possible :P.
Model: r34 gtt
Wheel diamiter: 18"
Wheel width: 9.5" all round
Offset: +15 all round
Wheel size:225/40
Hi, I'm looking to buy a set of hks coilovers for my car and I saw these wheels for sale. If I bought these wheels how far could i lower my car before I would need rolling of the guards ? Also I'm not an expert on tires so while I'm posting this will 225's fit on 9.5's without any issues ?
Model: r34 gtt
Wheel diamiter: 18"
Wheel size:225/40
If you leave it stock height with reasonable tyre profiles, you won't need a roll at all. But that offset is fairly aggressive, and if you lowered at all you would need guard rolling and 2 deg negative camber to fit inside the guards. And yes, 225's sit nicely on a 9.5.
Refer to previous page, I have 225/40 on 9.5+20.
i had all my suspension dialed in by heasmans & i am very happy with it :)
i dont want to 'potentially' compromise handling for the sake of running wider wheels...from this, i purchased 18x9.5+22 & will run 265s as i was told this would clear.
now i need to decide on tyres - any recommendations?
nitto invo OR nt-05 sound interesting.
i get mixed feedback on the federal rsr's
Thanks mate :)
Street use really but I want optimum grip due to the power level I'm running...as long as the tyres aren't too sticky where they pick up small rocks and scratch the bodywork haha
Hi mates, first post on the forums.
I just got one of the first two R34 GTTs in my country (Costa Rica!) and I definitely want to change the wheels it came with...
I have read through this thread and a couple others and I arrived at the conclusion that some 18x8.5 +30 front/18x9.5 +38 rear seems like it will work with the all-stock car (please correct me if I am wrong here!)
From that, I am eyeballing the Work Emotion Ultimate Kiwami wheels and I am wondering if these will be a good fit.
Any comments and ideas are really appreciated! :thanks:
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
