easy question...
have a 32gtst.
going front GTR gaurds and some sort of over fender on the rear before paint.
wanting XD9s again.
So biggest XD9 on the rear is 18 x 10 +18 i think?
So thats the rear.
What can i get under the GTR ( in XD9 Sizing ) front guards and keep the same look of dish front and back and no hang out the guard?
cheers so 18 x 10 +18 will fit without a hassle? only want to lip the guards but dont want to pull them etc and dont want poke
Well load's of people run them on actual GTR's sooooooo.... :P
Hey guys, I'm new to the site so forgive me if I don't know what I'm on about.. I've got a 1996 Series 2 r33 and I've currently got 17's on it. I'm wanting to buy some XXR527's and increase it to 18". Question is, what's the best fitment (offset etc) I was told 18 x 9 +30 would fit best?
Go through the thread, look at what people have used. Though 9.75+30 would be a safe but aggressive fitment.
Visually the difference between the 8.75 and 9.75 may be the amount of dish, but we are talking minor differences.
  • 3 weeks later...
Hey guys
Im looking at rims for my 32 gtst.
The rear has over fenders so not worried about fitment as far as poking out of standard gtst guards but more about brake and inner clearance. But would like them to fit front standard guards....... Although may go gtr fronts to
My options are
work 11 R
18 x 9.5 +12 all round
Work DR9
18 x 9.5 +23
18 x 10.5 +23
Work T7R
18 x 9.5 +22
18 x 10.5 +22
Will these have any fitment hitting struts brakes etc etc?
also any one have any pics of any of these wheels in these specs?
thanks.. im just unsure if ill go wider front guards to at the mo.
so the smaller rims i have listed are for the fronts with standard rolled and slight flared gtst guards...
just making sure they wont foul the suspension and brakes etc etc
sorry, meant to say callipers
I ran 9.5+12 all round. fronts needed a roll/pull and liners removed etc. easy easy fit
probably 15mm poke
poke on r32 gtst guards? front or rear?
Edited by Adz2332
    • Thanks for the linkie. Certainly always a great deal of help when people post comparisons like these, but I think for now I'll stay away from any semi slicks. I did go ahead and order the sportcontact 7. My buddy has them on his modified A4 and he keeps saying how good they are. For my intended purposes these will probably work real well. I'll report on them once I had the chance to try them out
    • Talk about noisy. Even when I still had the Tomei under the car I could distinctly hear the tires rolling. And I doubt I ever will need maximum grip like on a track. My GTR will maybe never even see the 600hp mark and I need to get used to the car quite a bit before challenging the limits of its handling. For the next winter storage I think I will get a set of these rubber drive-on thingies that have a tire shaped base. Those supposedly really help prevent flat spots.
    • Well our climate is definitely way less hot overall and the weather can be quite picky at times. I just know that during normal road use or even spirited drives there is no way I'd be able to consistently stay in the operating temperature, and constantly changing the tire pressure would also be a royal pain.
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
