hi guys my cars currently at the workshop undergoing an operation u could call it, its having a new fuel pump wacked in with a FPR, a new set of injectors, an A'Pexi power FC, and a new Garrett GT30R turbo, so after a tune it should psh about 250rwkw, i have all basic mod's FMIC, air filter and exhaust...
i was just wondering wat u guys think it would run down the 1/4mile, i was thinking low 12's maybe high 11's, is this realistic? any thoughts and comments are welcome..
https://www.sau.com.au/forums/topic/84384-r33-gtst-250rwkw-gt30r/
  • Replies 166
you'll need some wide rubber if its street gear to get 11's IMO.
i skimped through @ 12.1 and that was ~300rwkw on the old motor... 25/GT30.
The most retarded amount of wheelspin as i was using 225 street tyres :D
yeh already got a clutch and i know mine spun in first before the upgrade, about the airflow meter, i was thinking of getting a z32, but am not sure if ill need it does anyone know wat the limits are on the standard AFM?
ive got damper adjustable shocks at front and back, not sure wat brand, but my car sits pretty low. so im not sure wat to set them to wen draging but, hey i guess i can muck around a little on the day make it softer or harder!!!!
Go softer so your car can squat down on the launch, and let your tyre pressure down quite a bit for better traction.
I would go the Z32 AFM as there is the option to select that airflow meter built into the Power FC, which will make the tuning process a little easier. When making that sort of power I think you are better of sticking with a product you know works.
Good luck at the drags, I'd say a low 12 is on the cards.
Edited by PHATGTR
yeh custom as in made specially for me, wow $440 is pretty expensive, i think i might get my mates he is known for supplying good stuff....
but what do you mean by custom ?
Spend the money on a new one mate. You wont regret it in the long run.
After all the mods you've done, turbo injectors etc. Ifm your saying $440 for a new AFM is expensive then its time to sell the car :P
i wasnt saying $440 is expensive i was thinking that the custom made one is probably a better flowing AFM then a z32, which means i have no limits in the future if i decide to push for more power.... and as PHATGTR said i porb will go for a z32 as i have a power FC and if it makes tuning easier then i will get it...
im still struggling to understand though.
how can a "custom" one flow more?
What is custom about it?
Hows does it work with a PowerFC?
Is it a Z32 thats copped up? How would the resolution go on this "custom" AFM?
just interested
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
    • Not yet quite as bad as what we've seen a Jim Berry clutch do in an R32 GTR though when it decided to cut a chassis rail in half... Still very very gnarly and a great reason to avoid.
