hi guys my cars currently at the workshop undergoing an operation u could call it, its having a new fuel pump wacked in with a FPR, a new set of injectors, an A'Pexi power FC, and a new Garrett GT30R turbo, so after a tune it should psh about 250rwkw, i have all basic mod's FMIC, air filter and exhaust...
i was just wondering wat u guys think it would run down the 1/4mile, i was thinking low 12's maybe high 11's, is this realistic? any thoughts and comments are welcome..
https://www.sau.com.au/forums/topic/84384-r33-gtst-250rwkw-gt30r/
  • Replies 166
you'll need some wide rubber if its street gear to get 11's IMO.
i skimped through @ 12.1 and that was ~300rwkw on the old motor... 25/GT30.
The most retarded amount of wheelspin as i was using 225 street tyres :D
yeh already got a clutch and i know mine spun in first before the upgrade, about the airflow meter, i was thinking of getting a z32, but am not sure if ill need it does anyone know wat the limits are on the standard AFM?
ive got damper adjustable shocks at front and back, not sure wat brand, but my car sits pretty low. so im not sure wat to set them to wen draging but, hey i guess i can muck around a little on the day make it softer or harder!!!!
Go softer so your car can squat down on the launch, and let your tyre pressure down quite a bit for better traction.
I would go the Z32 AFM as there is the option to select that airflow meter built into the Power FC, which will make the tuning process a little easier. When making that sort of power I think you are better of sticking with a product you know works.
Good luck at the drags, I'd say a low 12 is on the cards.
Edited by PHATGTR
yeh custom as in made specially for me, wow $440 is pretty expensive, i think i might get my mates he is known for supplying good stuff....
but what do you mean by custom ?
Spend the money on a new one mate. You wont regret it in the long run.
After all the mods you've done, turbo injectors etc. Ifm your saying $440 for a new AFM is expensive then its time to sell the car :P
i wasnt saying $440 is expensive i was thinking that the custom made one is probably a better flowing AFM then a z32, which means i have no limits in the future if i decide to push for more power.... and as PHATGTR said i porb will go for a z32 as i have a power FC and if it makes tuning easier then i will get it...
im still struggling to understand though.
how can a "custom" one flow more?
What is custom about it?
Hows does it work with a PowerFC?
Is it a Z32 thats copped up? How would the resolution go on this "custom" AFM?
just interested
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
