hi guys my cars currently at the workshop undergoing an operation u could call it, its having a new fuel pump wacked in with a FPR, a new set of injectors, an A'Pexi power FC, and a new Garrett GT30R turbo, so after a tune it should psh about 250rwkw, i have all basic mod's FMIC, air filter and exhaust...
i was just wondering wat u guys think it would run down the 1/4mile, i was thinking low 12's maybe high 11's, is this realistic? any thoughts and comments are welcome..
https://www.sau.com.au/forums/topic/84384-r33-gtst-250rwkw-gt30r/
  • Replies 166
you'll need some wide rubber if its street gear to get 11's IMO.
i skimped through @ 12.1 and that was ~300rwkw on the old motor... 25/GT30.
The most retarded amount of wheelspin as i was using 225 street tyres :D
yeh already got a clutch and i know mine spun in first before the upgrade, about the airflow meter, i was thinking of getting a z32, but am not sure if ill need it does anyone know wat the limits are on the standard AFM?
ive got damper adjustable shocks at front and back, not sure wat brand, but my car sits pretty low. so im not sure wat to set them to wen draging but, hey i guess i can muck around a little on the day make it softer or harder!!!!
Go softer so your car can squat down on the launch, and let your tyre pressure down quite a bit for better traction.
I would go the Z32 AFM as there is the option to select that airflow meter built into the Power FC, which will make the tuning process a little easier. When making that sort of power I think you are better of sticking with a product you know works.
Good luck at the drags, I'd say a low 12 is on the cards.
Edited by PHATGTR
yeh custom as in made specially for me, wow $440 is pretty expensive, i think i might get my mates he is known for supplying good stuff....
but what do you mean by custom ?
Spend the money on a new one mate. You wont regret it in the long run.
After all the mods you've done, turbo injectors etc. Ifm your saying $440 for a new AFM is expensive then its time to sell the car :P
i wasnt saying $440 is expensive i was thinking that the custom made one is probably a better flowing AFM then a z32, which means i have no limits in the future if i decide to push for more power.... and as PHATGTR said i porb will go for a z32 as i have a power FC and if it makes tuning easier then i will get it...
im still struggling to understand though.
how can a "custom" one flow more?
What is custom about it?
Hows does it work with a PowerFC?
Is it a Z32 thats copped up? How would the resolution go on this "custom" AFM?
just interested
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
