honestly i dunno but to get around 250 and more out of a standard rb25 on anything less then 17 psi, to me sounds a big challenge, and not to mention the end result will not be reliable.
  • Replies 166
I remember freebaggin made some where up around 270-280rwkw on 17psi with his hybrid turbo using a vlt turbine housing.
The turbo specs were selected by Tim Possingham, it was an expensive bugger though, just under 3k. I suspect the comp and or turbine housings had a little bit of power porting.
The HKS int. gate housings are around $800.
Edited by Cubes
With a .63 rear housing and a GT30 comp WITHOUT zaust cam you wont get near 250rwkw under 17psi IMO. With a zaust cam gear set to 3deg advance and a HPInABox GT30 with .63 zaust housing I am hoping to get close to 260rwkw at ~20psi but not over 20psi... I think (hope) that the .63 zaust housing is good enough swollow enough to avoid serging...
No work done. However I think when considdering engine life you should be right at 20 psi as long as your knock is under control. Keep in mind that this is NO race car and will only see 20psi for short periods of time. Lets face it, how many roads are there in the ACT that will allow an rb25det with 260wrkw to be going full blat for any period of time :P I think there is some risk of doing a head gasket but thats no biggy, I will get a fater one when that happens to lowwer the compression and all will be sweet.
Trust me its easier to act ignorent rather than worry about it mate :)
Edited by GunMetalR33
Yea, rb25's a good engines and I have been told a a few people that the head gaskets should last on 20psi. I think its not GOOD for your engine & an engine with less power and boost will last longer...
Things to worrie about are:
ring lands (monitor knock & A/F ratio's and all should be fine)
head gasket (no more than 20 psi / adj cam gear at 3' adv helps this)
rods (dont rev rb25's over 7000 consitantly)
Before going big boost/power get a new timming belt and water pump...
I would like to get a zaust cam to lower the boost...
rant rant rant :P
yeh i agree, coz mines pushing out about 17psi and i have been scared off by a few people telling me it wont last long.... i guess its all about how heavy ur foot is.
dude,
please correct me if i am wrong, are you running an internally gated A/R .82 housing on your turbo?
if so, what brand?
rant rant rant :P
same me i wanna get a set of zaust cams, help boost up a little better too....
dude,
is that a genuine Garrett GT exhaust housing?
all genuine mate, only thing that aint is the dump obviously. if ur after a turbo like mine give me a pm and i can organise u someone to give u a quote, i got mine pretty cheap..
Its not challenge, ive done it, as have a few others also before me :)
get a new tuner
its just that im wondering how much psi a standard engine can take and for how long?
Its not just a simple question of PSI.
Do a search and a lot of reading. There are many many things that contribute to a motor shitting itself, not just psi.
mass iv, can you confirm at what rpm you are hitting full boost and if and when your tyres start to lose traction?
You mentioned earlier that the tuner said he was losing traction in 4th (or was it 3rd) to which other including myself thought too hard to beleive.
As I mentioned previously, I'm running just over 240rwkw with full boost of 16psi at around 3500rpm and there's no way in hell my car comes close to losing traction in 3rd with newish tyres on it.
In fact, it will hardly even lose it in second, if at all.
For the record, I'm running 225 Dunlop SP3000's on the stock rims.
Maybe the stocko 16inch rims give better straight line traction?
Maybe my car is actually running 200rwkw? (no way :))
As for you guys running GT30's, being a 550-600hp unit I'd say that 250rwkw is still quite a fair whack under the efficiency range of the turbo. I have a 460hp unit on mine pulling similar power with similar boost and still haven't hit the turbos limit. Need injectors :)
Perhaps we're seeing a limit with the stock cam setup because I was actually expecting more from this turbo (GT30) considering you guys have injectors giving you enough fuel for far more than 250rwkw.
ok id like to clear up a few things, my car is at full boost by 4000rpm, which is around 17psi. secondly it spins crazy in second and does a little into 3rd, i dunno if the dyno reading is incorrect but it deffinately feels as though my car has a little more then 240rwkw... not to mention i have smoked a few big powered cars..
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
