hey guys atm i am working to make 200rwkw after my last dyno of a shit 140rwkw due to poor tune and lack of a few things
Mods last dyno
Gts-t R33 rb25det
Link Plug in replacement ECU tunes by poor shop at 7psi on 95oct fuel
PWR INTERCOOLER
K & N POD
Trust Catback
Now my new plan is mod then retune it at MRT in Sydney On 12psi and get near 200rwkw
New Mods that i hope help me get to 200rwkw
Dump and front Pipe Twin set up off BOS
Hi flow Catco cat
PLUMB BACK BLOW OFF VALVE caust stock one isn't working right Flutters on 7psi
loud ( NOT sure on what brand anyone know any good ones for Plumb backs
custom 3" pipe intake from turbo to Pod without AFM due to link computer
last of all thinking Cam Gears but will they heap on stock cams
anyone know if cam gears will gain more power r they worth the money also what brand
OS GIKEN or TOMEI
thinking about new Timing beat too while cam gears r off
what u guys think
Edited by scottman
https://www.sau.com.au/forums/topic/84593-adjustable-cam-gears-on-stock-cams/
Those mods with a good tune should push you to that figure, or very close to it.
But if you looked in the Quick Ref guide at the top of this forum you would have seen the following threads
Ex. Cam Gear: http://www.skylinesaustralia.com/forums/sh...41&page=1&pp=25
Dump Pipe: http://www.skylinesaustralia.com/forums/sh...ead.php?t=10567
btw, 140kw is what you would expect for a near stock Skyline. That must have been a really really bad tune..
I know 140rwkw is low but i beat one of my mates with a gts-t with a full exhaust so i am guessing maybe the dyno was just out been just beaten by a 180sx and onces by a gts-t with least mods then mine he was a better driver
I am Hoping its just the Tune Mrt will work out whats holding my Power back
Tony,
Cmon you should know better ;) Those are the "Revision 1" HKS gears. The "Rev. 2" gears -- which use duralumin -- don't appear to have the same problems.
Edit: I'd still look at getting the Tomei gears as part of the camshaft + camgear packages they do.
LW.
Cam gears will make some difference, but not 60+ kw. (AFAIK, all they do is move the power band, they don't necessarily make more power).
I suspect it's the tune. I'm running a RB25DET on a Wolf 3D. It has VVT, and is otherwise stock. It was tuned at 10psi on 95 octane, and pushes 180 kW out through 4 wheels (R32 GTS4). Granted it does also have a "hi-flo" cat and a dump pipe, but still runs the factory air box and filter.
Hey whats the deal, is there something freaky about my car cause i got it dynoed with minor mods (see sig) and even at 7psi it was pulling 169rwkw, and was 186rwkw @ 10psi.
Was dynoed at unigroup, i would have thought scottmans would have been more powerful...
Must be UBER dodgy tune
i have no idea why its only 140rwkw i am hoping to try and fix it hoping its just the tune
other things it cound be is Fuel Pump or injectors or something MRT will find out hoping to fix it :P
still i own lots of shit with 140rwkw :blink:
I thought it was shited so i went and raced my mates Gts-t r33 with a Full Exhaust and BOV and i beat him so i have no Idea maybe it was the dyno
If you want to try adjusting the inlet gear whilst keeping the use of your VVT, PM me.
I've got a little invention that may just help you out.
Yo bass.Have you made some for r33 now.Or is this a trick that you have up your sleve.
I have the newer HKS gear and its fine....
Didnt gain anything at all... Just got a few more km's per tank and smoothed out the top end.... No jerky action inbetween 6-7000k....
AND more importantlly i got FLAMES>>>>> LOL
Scottman, what dyno was it on ? The dynologs read alot lower than the DynoDynamics ones (most common).
I just had car on dyno yesterday to retune, and all i could get was 145 rwkw's (Dynolog)
(was tuning it myself)
Now bear in mind this is S1 R33 GTST, std turbo
3" turbo back, and i just put a 4" magic cat in (which does work well by the way , 4 gas analyser confirmed)
I have a plug in LINK. No AFM (3" SS Pipe to pod)
Carbon cleaned it too.
R34 GTT cooler
And just fixxed the coil probs with a mates 32 GTR coils borrowed till the splitfires arrive... also new BKR6EIX iridiums (.8mm std gap). After last tune the coils shat themselves , siliconed them to get by, but power was flat...
Also fitted a MV auto shift kit.
Its been a busy 2 weeks !
Heading out to drags again tonight to see how it goes...
Two weeks ago with it feeling flat it ran a 14.6 @ 95.3 mph So i hope i can get a 13 tonight ... time will tell.
I think you should go out to the strip and just see what mph your getting ......that will be a better indication of how well the cars going.... as your dyno may read low as well.
Gary
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
