  • 3 weeks later...
  • Replies 74
BNR34
TV2 - Bayside Blue
QM1 - White
KR4 - Sonic Silver
KV2 - Athlete Silver
GV1 - Black Pearl
AR2 - Active Red
EV1 - Lightning Yellow
LV4 - Midnight Purple II
LX0 - Midnight Purple III
WV2 - Sparkling Silver
QX1 - White Pearl
EY0 - Silica Breath
JW0 - Millennium Jade
my car is grey (gunmetal) same colour as the Mine's GTR
and it isnt listed on here
does that mean it has been repainted?
or is it called sonic/athlete/sparkling? silver?
Can you get the paint code from your engine bay? Otherwise give us the VIN and it can be FAST'ed to check the original paint code.
my bad...and ive always thought its was gunmetal grey :)
  • 3 months later...
  • 2 months later...
  • 2 years later...
  • 4 months later...
There are 3 types of QM1 (white) lol, found that out this arvo when I went to get some 2pak for side skirts.
white
Polar white
Papyras white
All I know is mine is not the 'white' one lol.
  • 3 months later...
  • 4 years later...
Hey Guys im painting my bonnet and im wondering if the type of clear i choose could affect the match. Im leaning towards the Acrylic or the 2k clear for a harder and shinier clear coat doesnt scratch easy too. However will the 2k clear make it look different from the rest of the car?
  • 5 months later...
  • 5 weeks later...
Anybody know what the actual Paint Code is for AN0 Wine Red
Everywhere I go says AN0 is Super Clear Red and that looks nothing like Wine Red, somebody said the Skyline is actually painted silver first and then Super Clear Red over it
For Daniel check your VIN plate and then match code on Page 1
  • 4 years later...
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
