4th Gear
Guest EVL-R33
hey ppl, recently when changin to 4th gear from high revs from either 2nd or 3rd my 4th gear keeps crunching for no reason i know its something wrong but i just wanna see if anyone would know the problem or experience it b4,
At the start it would crunch really hard and not go in, now after 2 weeks it goes in but still crunchs softly, it needs fixing a.s.a.p i just got back from my holiday and its time to get it done...
thank you..
https://www.sau.com.au/forums/topic/8497-4th-gear/
Mine does it on 4th as well. I just figured the synchro was on it's way out and am living with it. If you're just cruising then try and match the revs to the gear when you're changing up into 4th. If you don't know what i mean, try pulling the shifter 'against' the gate into 4th when you change up with your foot on the clutch instead of just forcing it in. You'll find that as the revs of the engine match the revs of the flywheel, it will just go in by itself.
I don't know if this makes any sense at all but I hope it helps. It's just like riding a motorbike. I hardly ever use the clutch on up-changes. All I do is put a little bit of pressure on the shifter with my toe and back off the revs slightly so it clicks into gear.
Good Luck
https://www.sau.com.au/forums/topic/8497-4th-gear/#findComment-123715
There was a similar thread a while back on SDU i think and from memory they suggested a good oil change with a stick of Nulon GE70 (i think that's what it was), drive nicely for 500kms then see if it still crunches when giving it a bit of welly.
I haven't tried this so dunno if it makes a difference.
https://www.sau.com.au/forums/topic/8497-4th-gear/#findComment-124102
The shockproof oils will definately help, they should lessen any additional strain on the synchros and reduce the crunching noise. It is not however going to fix the problem, therefore I think that saving up to replace the synchro might be a good idea. At the same time get them to check the whole box, if one synchro is going then the box may be on it's way out.
See'ya :burnout:
https://www.sau.com.au/forums/topic/8497-4th-gear/#findComment-124195
The problem with the syncro's is sometimes an issue with the oil being too slippery and not slowing the shaft down before changing.
Nissan did an upgrade to the GTR boxes which had the same problem but cost about 2K for parts alone.
I have solved the problem on 3 x Nissan boxes so far for about $100-$120 by using Redline Lightweight Shockproof oil ( blue smurf ).
Is amazing stuff and ask Micko who will vouch how well it is still going.
Ken
https://www.sau.com.au/forums/topic/8497-4th-gear/#findComment-124242
  • 3 weeks later...
I got it from CRD in silverwater. Bloody expensive @ about $100, but cheaper than pulling out the gearbox and reconditioning it :;
I don't think its a permanent fix, the gearbox still baulks at a quick change, but the crunching is gone and the motion is smoother. Thumbs up from me.
https://www.sau.com.au/forums/topic/8497-4th-gear/#findComment-143625
Originally posted by benm
Dumb question but where and how do u replace gearbox oil ? Anyone got any pics of exactly where it goes ?
On the bottom ot the box there's a plug, undo that to drain then plug back up. On the drivers side of the box, there's another plug. Open and fill up until it starts pouring out a little.
Duncan, you bum!:)
https://www.sau.com.au/forums/topic/8497-4th-gear/#findComment-144976
    • Yea that's a fair assumption. I'm presuming they call them solid lifters as they have no moving parts like hydro lifters.
    • I believe you're confusing WMI with water injection. Looking at that graph, the 93aki+WMI car is making more power than C16 race gas. Boost juice, which is what I also run, is Snow Performances 50/50 premix.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
