hey,
just wondering what conrods people reccommened for an RB26?
do i have to get a certain size to match the pin or are they usually the same size?
im using arias pistons with the supplied pins.
i understand the standard ones are good for around 500HP?
im looking to have around this figure so to give piece of mind i think i will upgrade now while its apart.
so what rods and where should i get some..
nengun have a set for around $1500 but there may be a cheaper alternative.
thanks again
https://www.sau.com.au/forums/topic/85135-what-conrods-to-buy/
for 500HP there is no reason you cant retain the standard rods but have them nitroed, crack tested and prepped. Standard rods will handle the power without a problem though you should use ARP or Tomei rod bolts when you rebuild the engine.
I have hear nothing but good news about Argo rods...
If i was to build another rb30det it'd be with them....
Saying that, you would get the same sort of repsonses when asking for what pistons to use....it comes down to personal preference.
I like to ask the engine builder what he uses, then ask why :(
Have been running 450ish hp at the wheels on standard rods shot peened for almost 24 months now without a problem. I am using ARP rod bolts though which is where the weak spot is in the rods apparantly.
Keep clear of R.E.V rods. Friend of mine ordered a set thinking they were a bargain. They arrived pre-assembled, when removing the rod bolt it stripped itself and snapped. Really want something this brittle in your engine when you cant even remove the rod bolt to put it in the engine?
Unless you want to push massive amounts of power or raise the rev limit, standard rods should do you fine (using a decent quality bearing as well... I previously used NDC bearings (Nismo are supplied by NDC) ad they are a tri-layer metal style bearing. After 10,000km the top layer had started peeling and was on its way to spinning. The car has no knock what so ever, and have always used Motul 300V Chrono oil changed every 2500 - 3000kms. My preference for bearings would be King.
EDIT: Forgot to mention, as others mentioned get them shot peened to remove any surface weaknesses, and if you have the cash cryo treated to add some extra strength.
Edited by Amaru
A few of us in WA are using Pauter rods:
Pauter Billet Rods
The quality of these things is top shelf and they have handled some serious HP (as well as surviving some catastrophic unrelated engine failures).
If your bank account is really flush - have a look at the titanium rods :(
Pauter Titanium Rods
Pauter Billet Rods
hmm US$995 for each rod is a bit out there for me :(
i bought a set of crower conrods.. told they were pretty good but i got them foo 1595 so it was a good price.. dont know much about the quality but they look really well machined and compared to the stock 25det rods... lol.. no comparison
my 2c
apparently they are very good rods and can handel 1000hp
King Engine bearings....thats what my engine builder used on the mains..
I've seen this posted before where King bearings are avail for the RB26, but I can't locate any... Would you by any chance be able to locate/ post the King part# PLEASE so I can have my machinest try his luck at getting me a set.
Thank You for your help with this request....
joel
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
