could i suggest a printer? haha
you dont need extension cables
it reaches
all you have ot do is drill new holes in teh metal brackets since the hole alignment is different
i was going to do it, but hten didnt have all the tools i needed, so i never got around to it
Yeah, I was gonna say the same thing. The holes for installing your stereo, etc. into the metal bracket are in the middle of the unit, but the holes for the climate control are at the bottom of the unit, so if you used those then the climate control would probably sit half-way up a DIN slot, leaving a half-DIN gap above and below the climate control unit.
Well i bit the bullet and got it all plugged in and what do you know it all works!! only thing i have a problem with is how far the head unit sits out from the dash.... :whistling: its petty but i want it to be just right.
So its all out again and im going to have to manufacture something to hold the head unit firmly in. Couple of new holes to drill and some metal to buy me's a thinks.
Will post pics as soon as its done though.
Just a quick question, i can't be bothered pulling my doors apart right now, but can someone tell me if the 260RS Series 1 has removable speakers in the front doors? or are they factory glued/plastic welded types that will need cutting out??
Cheers peeps
Edited by MyStag260
Cheers peeps
cant tell you that. Havent got into that part yet. Although Simon AKA oureemphatemine" had done it. But havent seen him looged on for a long time.
Hey stasis, is the Dolphin dash replacement an acutal EL glow face? or are they just like the series 2 dash with white face, black at night with glow numbers?
Do you have any pics of it at night and day?
Cheers
Edited by MyStag260
Cheers peeps
The door trims are pretty easy to remove, probably the hardest bit is maneuvering the door trim around so you can get to the plug for the power windows and mirrors.
I'm guessing all C34 Stageas will be the same in this regard, the only difference being if the car was optioned from new with standard co-axial speakers or splits (like mine was).
The speakers are screwed into plastic brackets (front and rear) and if you buy 6.5" speakers they should bolt straight in. You might have to alter the brackets a bit, my speakers had bigger magnets than the factory ones, so I had to remove quite a bit of the backing around that area. (I took the lazy way out and just ground them away on a bench grinder until they suited.) The only other problem you may have is lining up the holes on the brackets to those on your new speakers.
A few people (like AlexCim, IIRC) have made brackets out of MDF.
Wicked!! thats great news i hate pullin sh1t appart only to realise i need to buy some more stuff before i can continue with the project... that usually means (A) the car sits in a pile of its own filth in pieces for a week or (b) putting it all back together again only to pull it apart again the week after. Option (B) is like your girl offering you a bj... very rarely happens.
Thanks
  • 1 month later...
Has anyone relocated their air cond/heater controls in their stag?
i just want to move it from the top to the bottom of my din slots..
they make extension cables with plugs in japan but if it's not a hard job i may as well just make it myself...
I'm going to do this because I have a double din Kenwood with a flipdown face. You cant use the drink holders, the face got stuck on a Coke can and was a pain to extricate.
What have people done regards to their factory speaker grills eg mesh, cloth ? The factory plastic grills look quite restrictive ie not 'acoustically transparent', especially for 6x9s which i have in the front, as the mesh opening is around 6" and not very much 'open area'. Do most people build new grills or modify the factory plastic ones ?
Edited by chook
  • 1 month later...
Another tip: To avoid mysterious intermittent clicking in passenger side console (due to AC diagnostics,) make sure your wiring harness is secured tightly in the AC control unit before slamming the head unit chassis home. Oh, and slam it firmly but gently...
  • 3 weeks later...
Better of removing the original plastic speaker mounts, tracing/cutting them out on some 18mm mdf.
Put some dampening material on the back of the new wood mounts then bolts straight back in nice and solid.
Get nice solid bass response no vibration...
6.5" way to go nice and simple no stuffing around...i'll put some pics of front and back later. when at home
Although in saying that I've got spare 7*10 Kenwwods that may just with some creativity.
Chook, they unscrew at the back of your door trim.
Take them out get a mould, or trace up your own version
Come to think of it i may do that, smoother look.
Do you think the plastic grilles would deflect the sound much, i was thinking along same lines?
got lots of holes though
Couldnt install 6x9s behind factory grills, not enough depth. Installed pioneers in front without hacking trims, just needed to remove some door metal, MDF facia and backing plates. Rears went behind factory grills, same pioneer model, 6", got rid of factory plastic mounts for MDF. Also used sound deadening material throughout front and rear doors, sounds superb, a lot of work to get the postioning just right for the fronts, not much room for error, but well worth effort.
Edited by chook
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
