Mike, I replaced my front splits last weekend, and the wiring for the tweeters doesn't seem to come from the drivers in the doors. There are only two wires heading to the drivers in the door on each side, and no wires leading away from them. When I looked at the tweeters and replaced them, they had a separate set of wires leading to them, but not sure where they came from, maybe it was directly from the head unit. They seemed to have tiny crossovers attached to them directly.
Tracing the wires would have been a hugely time-consuming process - taking the A-pillar cover off is a task and a half, because it's all one piece going to the B- and C-pillars too, so I just didn't bother.
excellent guide - thanks Alex.
only problem Ive found is the headunit doesnt remember the settings which means the ignition wire isnt the right one.
I wired it up to the light blue with yellow stripe wire as recommended.
Any suggestions?
Also, cos I live in the country, I cannot access the areial plug adaptor.
Anyone know how to get one of these online?
Or, is some kind City dweller willing to get me one and post it to me (at my expense of course) :mad:
The memory is stored via the 12v constant supply, the ignition just turns it on ...so the ignition wire isnt your problem. double check your main positive connection, Also those wires are based on the S1 ( just in case you have an S2)
Cheers
Lee
Edited by STAGE-A
  • 2 months later...
Hey guys,
I just picked up my new head unit today and i have spent the whole afternoon completely ripping out the old system which had a japanese GPS and stacker and tv wires which all needed to be removed under the carpet it was a massive pain in the arse it took about 3 hrs to get it all completely removed and all the trims put back together.
Anyway i was looking at my new headunit wires and the only one im confused with is the auto arial wire do i connect this to the wire that alex was talking about? Black and Yellow one?
Cheers Simon
Hey guys,
Cheers Simon
the yellow wire alex mentioned is the power wire to the glass antenna if u dont put power to it the reception is crap i just used the ign wire so its only live when ign is on. i just finished mine a while ago if the auto arial wire is the one on the headunit it is there to operate an electric arial when unit is on. i didnt use it on mine i just put it into the new plug i got from dick smith and didnt have anything in the other half of plug so it was just terminated .if i decide to put an elekky arial in later i just solder a wire onto the pin and put it in. the plug i got was a 15 pin job from dick smith it cost about 5 bucks you just solder the pins to the wires then push them into the plug base where u want them i put the female onto the original car wires and then the male on the radio wires so it all looks reasonably factory etc and was a neat job without tape also headunit just unplugs now like the original did ............ i hope that helps a little regards mike
Cheers Mike,
Yeah that helps heaps, just one other question on the head unit what wire do i connect to the lights wire from the factory wiring loom?
picked mine up from the ciggy lighter light
Hey alex,
Yeah for sure id like to catch up soon anyway i wanna see how good your car looks when its done.
But fortunately i sorted it all out today thank god it was pretty simple if only i had a multi metre from the start lol.
The end result came up really well im extremely pleased with it.
I will post pics tomorrow night when i get a chance to take some pics.
All i can say is to who ever the person is who hooked up the boost gauge before me and wired up the old stereo and other crap had absolutely no idea on what he/she was doing it was an absolute butchering of a job.
  • 1 month later...
Has any one worked out how to get decent reception with aftermarket head units and the aerials in the rear windows? The only wire I have that isn't connected to anything is blue with a white stripe but when I give that 12v it doesn’t make any difference to the reception but sucks up a heap of power as if it's earthed.
The black with yellow stripe wire that Alexcim claims is the power for the antenna is connected at both ends. One end joins into the wires going to the antennas and the other links into the main body loom.
I guess my next step will me to snip the black with yellow stripe wire and give the end going to the antennas 12v and see what happens.
I had to remove all 4 screws holding the console before removing the rectangle plastic faceplate...thats coz i found 2 screws at the bottom which attached the stereo surround to the metal center console just below the clips...if u tried to pop the surround off before removing the screws...might end up with a broken bracket.
Are you sure it doesn't come back out somewhere behind the head unit? As the power to the antena is normally switched on/off by the head unit (no point having it powered if it is off!) - so I'd try what you sugested above...
Ian
Hi Guys/Gals
Quick question ( i hope), hubby recently installed one of those 10Mhz FM Radio Convertors into my Stag... found a problem with it this morning.. the FM convertor works all the time when the car is in "park"... the problem is when you put the car in drive it still works until you put your foot on the accelerator then it turns off... although in park/reverse its fine.... I dont think its a short otherwise it shouldnt work at all... Its strange but its like there isnt enough power under load????
Suggestions??? has hubby connected something incorrectly or forgotten something??? any ideas would be helpful before we pull it apart again to find the fault :confused:
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
