As you may have noticed I have organised a SAU Group Buy for Whiteline suspension components and Bilstein shock absorbers for R33GTST Series 1 and Series 2. I chose this model as it is the single most popular Skyline.
If I get enough support I can also organise similar for R32GTST, so please let me know the level of interest.
;) cheers :)
Edited by Sydneykid
hi SK, Im after a front swaybar for a 180sx with a RB20, as the stock swaybar is touching the sump
its not an R32 but its close! i think the closest part no. is BNF20 but I beleive they can custom make it a little forward or dip to fit?
Whiteline can make custom stabiliser bars (it costs a bit extra), but you will need to give them the dimensions or take the car there for them to measure. Something simple like "same as 180SX front bar but with 20mm more dip" may well be enough. Or a picture with dimensions on it is even better.
:rolleyes: cheers :)
my rear shocks are almost dead. (one makes a loud thump sound on every bump) :\
so ill be interested :3
R32GTST, R33GTST and Stagea are now on the Group Buy. I will be adding R32GTR today as the enginering is almost finished.
How much for a R32 GTSt front and rear shock/spring set?
I have organised a SAU Group Buy for Whiteline suspension components and Bilstein shock absorbers for R32GTST. We get 15% discount off recommended retail and free freight if the individual order is over $500. Plus anyone who spends $1,000 or more gets an additional 5% discount.
I have chosen the springs rates and the stabiliser bar rates based on my experience with this model. Plus the shocks come with matching valving for those spring rates and 5 circlip grooves for setting the height up just how you want it. In addition the adjustable stabiliser bars come with 2 extra holes for even more adjustment.
The recommended settings for road use are also included. The savings on a full kit is around $600, so it is not only technically a great set up it is also good value for money.
Delivery is via Toll Priority and I have organised an Australia wide price, so it doesn't matter where you live, you will get the parts at the same price as everyone else.
Please post up your order here and any questions you may have. Fitting and alignment can be done at the following locations;
Heasmans Sydenham NSW
East Coat Suspension Kirrawee NSW
St George Steering Punchbowl NSW
Centeline Thomastown Vic
Traction Tyre & Suspension Rowville Vic
Discount Tyres Service Belconnen Act
More fitting stations will be posted as they come to hand.
:P cheers :D
PS; Several sets of shocks and springs are currently in stock, bushes and stabiliser bars are made to order. So delivery is 10 days from time of order, all items are shipped via Toll Priority using their Off Peak service. Consignment note numbers will be provided at the time of shipping, so your order can be tracked via Toll.
Payment should be made in full to the bank account details in the initial post, the receipt number for internet banking is acceptable or a copy of the deposit slip for over the counter banking. Send them to me via PM.
350mm, centre of wheel to guard.
is this a standard rate they have? or can we request a different height
for example 330mm.
thanks
There ae 3 circlip grooves below the standard circlip groove and 2 above, they are all 8mm apart. So you can go approximately 366mm, 358mm, 350mm, 342mm, 334mm or 326mm.
:D cheers :D
If at street legal height is the suspension considered legal for road use. - undefectable.
I have an R32 4 door - do you know if all the suspension components are the same I assume it would be
All components are DOT legal, each State has its own interpretations of the ADR's though. I have been involved in a case where a standard Falcon was defected for being too low, so there are no guarantees when it comes to some State's stupidity.
The 4 Door is the same, if you carry 4/5 people often, fill the boot with stuff and/or tow things then you may want to go up one circlip groove on the rear spring seats. But that's about it, everything fits perfectly.
:P cheers :D
  • 4 weeks later...
  • 1 month later...
  • 4 weeks later...
the springs for the r32 gtst are the minimum height which are legal right??
Does this make the front end of the car any stiffer or just lower??
I was just enquiring if you could acquire 8kg/mm springs for the front end through whiteline??
Thnx
Thnx
Legal height is a tough question because the exhaust systems vary from 2.5" to 4". This means what is a legal 100 mm clearance with a 2.5" system is an illegal 62 mm with a 4" system. The additonal circlip grooves on the Bislteins in the Group Buy kit mean that you can adjust the height to make sure it is legal.
The Whiteline springs are a higher rate than standard, usually 20% to 25% higher. The standard springs are ~3kg/mm so an 8kg/mm spring is not a road spring, in fact it is fair bit higher than what I would use circuit racing.
Hope that was of some help
:) cheers :)
Is this the same thread as http://www.skylinesaustralia.com/forums/in...pic=85591&st=80
Where should I post?
R32 GTST 4 door.
SK. What are the rates of the springs you are recomending? My fronts are stuffed. I figured I'd replace all 4 at once.
So I was thinking I'd go coilovers since I drift once a month and the car isn't a daily driver as such, although does get a lot of street time (not 'street racing' though)
I would consider what you are offering as I want something that is stiff enough to drift on, but not too hard for the road.
I am currently looking at the HD systems coilovers for $1295 I think from memory their rates were 6kg and 8kg
Just looking at price of your kit..is this right?
pair of springs = $154x2 = $308
Pair of Shocks = $571x2 = $1142
Pair Dustcovers/bumpstops = $56x2 =$112
Total = $1562 less 5% extra for being over $1000 = $1483.90
Cheers
Chris
Edited by eXc
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
