(Use this as a guide for new threads. Delete and/or copy the fields as needed - dont forget to add your location in the description field above. Delete this message)
I have FOR SALE a number of bits listed below that were bought for this engine conversion to go into my HR30 Coupe.
RB30E GTS1 Block, crank, rods, caps etc $50.00
RB25DE Block, crank, rods, caps etc $50.00
RB25DE DOHC 24V Head $400.00
Gates Timing Belt to suit $25.00 but should go with head if for conversion
NEW 1.0mm o/size ACL forged Race Pistons suit RB25DET $900.00 set
RB25DE Inlet system incl injectors $75.00
RB25DE Throttle Body $100.00
NEW GTR Valve Springs $100.00 set
NEW N1 Oil Pump & Adaptor $450.00
VL Turbo Oil Pump $150.00 incl new gasket
RB30E GTS1 Oil Cooler & Adaptor $150.00
PLug & Timing belt covers $15.00
NEW RB30ET Billet Steel Flywheel (Castlemaine Rod Shop) $450.00
NEW VL Turbo 10 in Pressure Plate $150.00
NEW RB30E Harmonic Balancer $75.00
R33 GTS25t 5 speed box (less than 80K) $1200.00
NEW GTR Speedo Drive (for conversion to analog speedo) $75.00
R32 RB20DET 5 speed box $350.00
R32 RB25DE ECU $75.00
R32 RB25DET ECU & Loom (came from a car producing 245rwkw) $150.00
2 x Z32 AFM's $275.00 each
A/Mkt 40mm Ext Wastegate 14lb spring $150.00
Genuine HKS 40mm Ext Wastegate 10lb spring $300.00
I think that's about it
Item Condition: New to Excellent condition
Reason for Selling:No longer required due to health reasons the PNV is staying L Series powered
Price and Payment Conditions:Prices are negotiable to a point and payment will be COD on pick up or paid into my bank account prior to shipping
Extra Info:
Contact Details:PM or email [email protected] or phone 0406 142 529
https://www.sau.com.au/forums/topic/85699-rb2530-dohc-hybrid-conversion-bits/
very interested in the VL turbo oil pump and the spark plug cover. wouldn't pay more than $120 for the pump but, seen em go for less on other forums. if you'll take $120 for it, and $15 for the plug cover i'll take both.
THERE HAS BEEN SOME CHANGES
GTR valve springs and RB30E Harmonic Balancer prices have increased, as their costs were very different to first thought.
NEW GTR Valve Springs $200.00 set (cost $369.00)
NEW RB30E Harmonic Balancer $150.00 (cost $260.01)
NEW GTR Speedo Drive (for conversion to analog speedo) $75.00 (cost $99.00)
2 x Z32 AFM's $275.00 each (cost me $300.00 each)
Extra Info:
NO! you have to drill & tap them yourself.
hey mate, the rb30e block, is that series 2? (does it have the holes for oil and water lines?)
You ever tried to buy one NEW??? But I have an enquiry on it that I am waiting confirmation on and will let you know.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
