I just found a bent bolt on my exhaust manifold so decided to undo it to replace it.
What do ya know it snapped off inside the head, YA for me!!!
After taking off the exhaust manifold to try and remove the bolt i managed to snap 2 more
Has anyone else has similar problems with this?
Has anyone tried removing a bolt snapped off in the head?
Im about to attempt to remove it with one of those extractor set of drill bits.
will post how successful this is
ALso wondering if anyone has tried purchasing gasket sets for the RB20
I was qouted $650 for a gasket kit that included everything including the head gasket
no one was able to get me just the exhaust manifold gasket
Yes this happens with lots of Nissans and cars in general.
You drill a little hole in the stud (the bolt part stuck in the head) and then use some easyouts to unscrew them.
Get new studs from your local auto parts shop for about $2.50 each and wind them in.
yep had to do it on the ceff... not cheap.. but worth it... IF you're in SA let me know, and i'll give you the phone number of a mobile guy who comes out and does it... cost around 100bux i think for 5 or 6 bolts to get out... "Captain Thread" - absolute champ.
Can I suggest that you try and scrape a goove into the bolt, depends on how deep it is, but if its snapped off flush at the top you can use a knife and scrape a line in it to use a screwdriver to remove it.
I have donr it with smaller bolts, maybe worth while.
Thats a good idea, never though about doing it that way. I dont think it will work with head bolts though, those things are in tight as a nuns ***** :P
Have just dropped the engine out of my car so i can drill these holes nice and straight
Ive already had limited success trying to rip a snapped stud out of the dump pipe
with the easyouts
I wish they hadnt snapped inside the head, otherwise i would have tried that suggestion of cutting a grove in the stud and using a screwdriver
will let you all know what ends up working best
I can't beleive that you had to drop the whole engine just to remove a few bolts. I woulda gone for a compact drill, so I can fit it in the space to drill it straight.
I've seen a few air tool ones that are quite compact.
That would suck. best of luck mate.
Droping the engine out :unsure:
I feel for ya dude, what a pain in the a** those bolt have turned out to be.
with the easyouts
a pain in the arse in deed
i tried using my air drill which is pretty compact, but it started to drill at an angle, due to it sitting up hard against the A/C lines on the firewall
is all good though, wanted to give the engine a freshen up anyways as it was running like poo
i pulled the fuel filter off, and mud poured outta it
YUK!
might have to port the exhaust manafold a bit while im at it
Well i managed to rip these bolts out of my head.
The first 3 took 20 minutes to do, the last one took me 2 hours due to a drillbit snapping and wegding itself inside the bolt.
anyways the easi-outs worked fairly well for 2 of the bolts. I tried the screwdriller method for the other 2 though and it seemed far easier, and would have made it alot cheaper.
As my bolts had snapped in the head i simply drilled 2 very small holes next to each other and used a flathead screwdriver bit for a drill. it was so easy unscrewing them just using an 8mm socket
I wish i had of tried this way first instead of spending 20 bucks on the easi-outs
theres a company called thread doctor. They are really really cheap and will come to you. They do a professional job and the job the do is very clean.
i had a mate who snapped 4 head bolts and it cost him under $100 to get them all out and re threaded.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
