i had problems with diffs... getting a 5 bolt when my car was a 6 bolt etc. but all good now, got a new nismo 2-way in my ceffy.
the kit all bolted on fine, except for the sideskirts, which i need to change the location of the bolt holes. but shes all good.
...now, to find some spare money :(
...now, to find some spare money ;)
Yeh I got manual, non-turbo (car is factory non-turbo), viscous and havnt heard from the mech yet so hopefully its all good. Was looking in the catalogue for Kaaz and they make about 6 different diffs just for cefiro. Like: Open-wheel, turbo, non-turbo, viscous, manual, auto. See how it goes......
Did I say 6 :( Check out this link: http://www.kaaz-sports.com/lsd_tekigou_eng...et_english.html
Edited by konect
haha sounds like too much of a hassle for me :D
id be just going out and buying a mech diff thats already in a housing, like i did. but then again, sounds like youve already bought it...good luck ;)
mine was a factory turbo auto, so it had 5 bolt halfshafts and viscious lsd (no hicas :dry: )
Picked up the car after work today and did wear in for 35mins. The mech said the centre fitted perfectly but i have noticed it seems to be 'rubbing' when I go around corners rather than clunking or doing any of the sounds ive heard when in cars before.
Can someone tell me if this is normal with 2 way ? Just dont want to fark it if I havnt done enough wear in.
Edited by konect
mine did the same thing konnect, but soon started clunking etc after a while. can tell you now, the missus doenst like having no interior and sound deadening, and the sound of the diff around corners and up/down driveways :(
R31power, your 31 is awesome? what engine you running in it? ive got a spare RB20DET i wanna put into a 31 or something :D
Phill: i'll take the RB20 :( looks like the R31 has a RB25, as per his sig..
as for the LSD noises, thats normal for a brand new one, then after a few kms you'll get less of the rubbing sound and more of the clunking sounds.
not sure what LSD i have in mine, its a 2 way of some sort but it clunks like a bitch lol
Phill: i'll take the RB20 :D looks like the R31 has a RB25, as per his sig..
haha righto simon, id rather get the thing tested etc, as of when i took the cams out and put stock cams back in, it sounded like it was knocking real bad, but went away once i put a stock computer back in. so ill make sure everythings still alright before i go selling it to anybody.
will also have fmic with piping, stock or HKS 2530 turbo, loom, gearbox etc.
got offered a 240rwkw SR for my ceffy last night, and hes after my RB26 which has done a big end bearing...hmm :wave::O
Edited by A31cefiro
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
