Hey, i was just wondering, here in sunny Brisbane, do u need (by law) to have a license plate on the front of your car? A few people have told me now, but i was just thinking, a few of u guys have really good front bumpers, and well do we need em?>
https://www.sau.com.au/forums/topic/87190-license/
well yes i am, some other guys i met with r33, had no front plates as it didnt have anywhere to fit on there aftermarket front. they said that they werent required by law to have them on the front, but the rear is a must....
i know it sounds stupid, but is it true or not..
https://www.sau.com.au/forums/topic/87190-license/#findComment-1574775
I have heard this also, i do not know how much truth there is to it, but one of my reloes had a mx5 with no front plates, and i was like wtf, and they insisted they didnt come out with them because there was no where to put them, i was just like, yes ok...
Im sure you can get away with it, but you can also get fined on it. Ring up ur local tmu a few times, and i betya u get a few different answers regarding to it :P
just put it on, what harm is it doing?
https://www.sau.com.au/forums/topic/87190-license/#findComment-1574806
You rnumber plate is to be fitted to the centre of your front bar.... Fitting to the side is as illegal as not having one at all...
It must be perfectlly visable from a 60 degree angle at 20 metres...
I did my research the other day...
https://www.sau.com.au/forums/topic/87190-license/#findComment-1579313
Last time i checked the front numberplate could be mounted on the side but must still conform with the angle and distance rule thingo.
When did you check?
I never had a problem with it being on the side
Edited by «Cyph3r»
https://www.sau.com.au/forums/topic/87190-license/#findComment-1591495
As long as it is viewable as above standards you will not be booked. But you can never tell if the officer that pulled u up is in a good mood or not...
I have never had a problem with mine being side mounted either. But a friend of mine had her plate zip tied to her front mesh, and when she drove it folded up so you couldnt see it, and she got pulled over, and told to fix it or cop a defect. I think it depends on the officer you get too, but if they are in a bad mood they will do you for anything.
https://www.sau.com.au/forums/topic/87190-license/#findComment-1596523
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
    • Wrong side of sydney for me coming from Goulburn, but you should head along, all ages of Skylines will be very welcome
