  • Replies 294
I plan on taking my video camera with me to the dyno day, was just wondering if there is anyone here who does not wish to have there car filmed? The footage will not be put on the net as its not a digital camera and won't be shown to anyone and will only be taken for personal use!
What do you define as a run?
A run to me is to put it on the dyno and get a print out of what your power is.
Just ask him what you wanted to get printed out
ie kw vs afr
kw vs torque
etc
Normally you probably would get 2 burns in fourth gear.
Nathan,
Hows the gearbox input shaft seal?
No seaps? I had a seeping front input shaft seal that caused occasional strange slipping. Other times it was perfect.
joel, if it's leaking its not making it as far as the ground! but its only a stock VLT clutch, asking it to hold the power i have is a bit much i think, i always had planned to upgrade it one day.
Hey Nozilla, IceDuck, Sam, Deluxe where are your deposits?
I thought you guys would definitely be coming!
hey Will, I should be there to spectate, not really bothered about going on the dyno cos i got dynoed there only 2 weeks ago.
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
