Sau Track Action - Vol.1 Dvd - $10
As for postage I would prefer that you make it to a club meeting, or other club event.  The more faces we see regularly the better SAU VIC as a club will be.  But if you can't make it or live far away then I will post the DVD to you.  If this is the case please PM me with your postal address and I will get back to you with an account to deposit into and the exact amount.  If making a deposit please put "SAUDVD (forum name)" in the transaction description.
Postage will only be like $3, $4 or $5. Depending on local, reginal or interstate.
PM sent mate :wacko:
  • Replies 71
Posted Images
she died on the dyno. Still it'll be back in a few months with forgies and high flowed N1's etc + PowerFC. Hopefully get it over the 300rwkw mark. (yeh like i need the extra power).
You guys can buy me beers to cheer me up on Tue meeting night? :(
obviously ive missed something in my absense... what did u do? blow it up? lol
roy... whats it with u and shiving people lately? haha
Still in production. Probably in December or January.
After the 50 hours I spent editing that one, i'm not too keen to start it all over again. But I have a heap of footage from this year still to edit and we will no doubt have plenty of action from the upcoming DECA day on 19th Nov.
Wathed my copy yesterday, very nice.
Only problem I had was the last chapter of the incar footage at winton it kept skipping forward so i had to keep rewinding to see the whole thing.
hmmm must've got a scratched disc, coz mine was fine
anyone who's thinkin bout gettin 1...its worth it. for $10 it goes for a fair while, and its pretty decent quality etc...
ive payed more for lesser automotive DVD's....this 1 did not disapoint! i'm already hanging for Vol 2.
request: can you guys make vol 2, 3 etc, with the same cover theme....it'd look good to have em all lined up, with the vol part different, and obviously a different cover car on each 1
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
