  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha richard .... my tax return is going into bills.
i got a Groove Armada song stuck in my head.
u got a while yet til they have to have group certificates ..... im waiting on hmmm two or three of them - of forget .... but ive got one.
i love this avatar that i have "borrowed" from someone one the forums... sorry for borrowing it but its awesome!
i have got 92.9 on in the background... trying to win the cash call so i can do stuff to my car!
Bummer on the non paid days off.... i dont like that idea, nothing better than having a day off, sitting infront of the tv and knowing i am getting paid for it!!
haha yeah but i get paid more for when i am here to make up for the days im not :(
plus flexi time is a beautiful thing - had an hour sleep in today :)
yeah thought that was Squizz's Avatar ... he's one of the founding fathers of SAU :)
Good luck with the call - remember u win it u have to buy me a beer ok? haha
