haha at a cruise we will meet... I usually get there somehow!! hopefully next time I will have my baby back.
nah I dont always look on the positive side.... sometimes its too much - but i dont know, i have a drepressed friend, and I dont want to end up like that
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
IF THEY DONT, TELL THEM YOU HAVE LINKS TO AL KAIDA
money come out quick smart, and a free trip to asio secret head office in perth
so devil those blue neons in ya pic is that ya sisters
astra
the nismo key is like 90 i think. the gtr key is 45 or 50
i can see how much a black plastic headed nissan key is for you if you like, then you can get 2 of those and get them cut etc. and that should look nice and standard. also let me know if you wanna get an alarm etc. i can hook you up there also
