just wondering what could cause a GTR to start running unlimited boost.
(The boost restrictor has been removed)
i have been told that removing the pipes that go to the wastegate actuators and blocking off the hoses will cause the turbos to only run about 8PSI assuming the actuators are fine.
basically i want to limit boost to around 12 psi
https://www.sau.com.au/forums/topic/88532-why-was-my-gtr-on-unlimited-boost/
  • Replies 74
should be right as the actuator wont have any pressure from the line to help hold it closed is it would only be relying on the spring pressure to hold the wastegate closed.
( I could be wrong though I'm not very smart)
either that or swap hoses with some care 26 owner this is probably the easier option so you dont run the risk of blowing your motor
you should get a boost controller?
why mess with dodgy hack ups on 15 year old+ turbo's with cermaic wheels. just asking for it to go bang. if you unplug the pressure lines to the stock actuators then the spring will never move, thus the gate will never open so it will keep winding up pressure for ever
if you disconnect the actuators line you will get max boost the actuators a able to hold on the std turbo that around 19 psi (way to much for the std turbo)
if you put a direct line from boost to actuators you will get the minium the boost the actuators will run ~7 or 8 psi (i think not sure on this spring set)
a bleed valve or boost controller just bleeds off a some of the boost pressure being supplied to the actuators to govern the pressure between these to points
pete
ps buy a $99 dollar turbo smart bleed valve and you will be able to set your boost fine, just keep the lines as short as posible to reduce piking.
well the motor is getting put in the car today after a rebuild with some tastey parts..
before 2 pistons fried it was (for some reason) running unlimited boost... it went to around 12psi at only 2500rpm!
i want to limit the boost as much as possible.. and i dont know why it was running unlimited.
this will be for the run in process then i will be getting a power FC.
i want it limited to around 7PSI
like i said run a boost line direct to the actuators with give you minium boost (to what the turbos are preset to)
It appears you have disconnected the boost pressure line from the wastegate itself - is this correct? If so, where does the wastegate get a signal of what boost has been generated?
The boost signal forces the wastegate open when a preset boost level - enough to overcome the spring - is genarated. The spring actually holds the wastegate SHUT. So without a boost signal, the wastgate stays shut, and boost keeps on building.
Whoever told you you could remove the wastegate lines should be sent the bill for the repairs to your engine.
nah,
what happened was, i heard a noise that sounded like an exhaust gasket was gone (statrted to sound like a truck)
so i took off a few pipes to see if i could see any part of the gasket around the turbo had blown off. i may have taken i hose off the wastegate, but it was put back on and everything was normal again before i started the car.
after this.. for some reason it was on unlimited boost :blink:
i checked all the hoses around the wastegate.. i saw one was corroded.. i changed it with a new one.. still made no difference...
i have now been told that disconnecting the wastegate hoses will cause it to run off the spring and boost will limit to around 8psi.. however i agree with you, i think it would cause it to run unlimited.
could a wastegate be stuck... stuffed actuator?
Q: Why Was My Gtr On Unlimited Boost?
A: you messed around with a car you don't know much about and as a result popped your motor.
I can't beleive you are "helping the builder out a lot with the build" when you can't understand the simple basics of boost control mate. it's not that complex.
it's not a stuffed actuator mate. you f**ked up the pressure feed to the wastegate actuators. simple.
sorry if i sound rude but it bugs me that people keep blowing up cars through ignorance.
Holy shit.
Who ever told you this, should NEVER EVER EVER EVER be allowed to drive a turbo'd car. EVER.
arhhhh..
the lines were fine.. they were not leaking, they were connected.. and it was still running unlimited boost.
so your saying.. if this hose was taken off... then put back on 5 mins later exactly the same way, it will f**k it up?
arhhhh..
this might be my great detectives brain at work but lets look at the situation again shall we:
car is running normal boost
you disturb the pressure feed hoses
you put them back
car is now running unlimited boost
nothing else major has been done except you disturbing the pressure feed hoses
my conclusion is quite simple, you didn't put them back correctly. If you beleive anything else you are dreaming.
i know how to take off a hose and put it back on. Im 100% sure it was put back on correctly as it was tripple checked.
the guys with my car said a lot of the hoses on the zaust side were corroded. but i was making sure that that was actually the problem before i put the original actuators back in.
i am not saying that while i was doing something the pipes corroded all of a sudden, obviosly i must have moved something and one of the corroded pipes split.
you seem prety certain the actuators are fine, so i will see how it goes with the new hoses.
well actually,
this will bring the boost back to around 1bar as the restrictor had been removed before i got it..
i think a zip tie around the hose to the boost solinoid would restrict it
Edited by druzilla32
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
