Hey Guys,
I'm most likely goign to be in Japan around the time of the f*kuoka Auto Salon..i'll have to stay a couple of extra days and i was just wondering if you guys knew anything more about it???
Like is the auto salon there worth it????
Would it maybe be more worth while goign early and going to TAS instead of FAS?
Cheers,
Duncan.
Edited by Donarto
  • Replies 105
Hey Guys,
Cheers,
Duncan.
Yeah theres always some tuff cars at Fu_kuoka AS, but it's definately not on the same scale as Tkyo, and even Osaka is bigger. I'd go to Fu_kuoka for sightseeing first - Auto salon second. I'd go to Tokyo for the Salon first - sightseeing second...
Thanx Rezz i'll keep that in mind.
Say do u happen to be the "Japan Diary" rezz??? It might sound a little newbie of me :D
Cheers,
Duncan.
I reckon 2 full days is needed to do TAS. and you still want see all of it. this year we spent 2 full days there and there were some halls we didn't even get into!
i think 1 day is plenty. Last year I was there just for one morning. I guess it depends how many photos you want to take... waiting for people to get out of the way who are waiting for others who are waiting for others to get out of the way to take a photo of what you want to take a photo of can take a while...
on another note did anyone go to the awesome dog show at makuhari late last year ? :P
yea i think it would be awsome but i have always wanted to go but i also ask myself is it worth it i am not intersted if some asian can put 22 tvs in their dash ....?
but on the other hand if i can buy car parts their cheaper does anyone know if you can buy parts at the show...
Yes you can, though generally its smaller parts only, not alot of engine hardware.
There is bling there, sure - but there is also one of the biggest collections of incredibly modified street, drag and drift cars you will ever see.
so whats the deal with the tokyo motor show coming up on 22nd? is this just new cars on display? worth going to? deciding whether to check that out or party in osaka this weekend.
You decide:
Gtr next gen vs girls/party.
The TMS is probaly packed with people in the weekend.
Michael, I can help - Richard and I will be there for two weeks across the time of Autosalon and so will a few others.
We will be quite busy with parts sourcing, workshop visits, drinking and hopefully some more drifting :)
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
