  • Replies 169
Posted Images
awsome day! great turn out! great weather....what more could you ask for....oh a trophy wouldn't have gone a stray...but hey...I got a WANG sticker!!!
thanks to all involved in the organising of the day! had a great time
oh and anyone willing to send some photo's of my ride (White R33, carbon bonnet, ABCENT plates)my way, please do, I need some decent pics since my computer crashed an i lost most of mine.
[email protected]
Cheers
[email protected]
Cheers
Edited by darK
Well since it seems your so hard up you can only get your jollies from looking at pictures of other blokes chicks rather than appreciating the cars which this event was about - here's a picture of Adz so you can admire his cans.
Try and keep your excitement in check this time.
that black 34 is hot, is that the one that won best 34?
He would have, but unfortunately HE'S NOT A MEMBER so he wasn't eligible :):P:O ... so I will say... denied! pwned! and other such things to him :)
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
