SAU-Vic Dyno Day
When: Saturday, 29th October
Time: Starting 9.30am till mid-afternoon
Where: ICE Performance, 7 Dissik St Cheltenham
Melway Ref: Map #78, B10
Pricing:
$50 runs for NON SAU-Vic members
$45 runs for SAU-Vic Members (so bring your membership card to show me on the day please)
Further Details:
* For GTR owners, bring your cars. The boys @ ICE have been kind enough to offer to drop the driveshaft from any GTR wishing to run on the day.
This will no incur any additional costs as it has been averaged into all costs for the runs across the board.
Running your GTR in RWD does not damage your car in any way, or give you an adversly high/low reading
* There will be a BBQ running from around 10-10.30am. $1.50 snags, $1 drinks...
Also the all famous Wang Burgers which are $4.50-->$5 cant remember exactly.
* ICE Performance might put one of their signature cars on for a demonstration run. This will be confirmed closer to the date.
If you wanna see it, there will be no time given, it will run when it best can get squeezed in.
* Places are limited. I will keep a spreadsheet of who wants what time. So post in this thread if you want a specific time and i'll let you know.
Others who just rock-up we'll slot you in wherever if your going to be there for a few hours :unsure:
Cheers everyone - ash
https://www.sau.com.au/forums/topic/89859-sau-vic-dyno-day-29th-oct/
Are we gonna see ur can on there Robo's?
Wouldnt mind seeing it in action... also bigcarl... if he see's this
Most likely, just waiting on a Reg from nengun as ive just hit 100% duty with a 2535. Then i need to tune it, so hopefully be ready in 3 weeks.
There is also a sh|tbox challenge... basically involves you bringing the shittiest car you know of and whoever gets the lowest... gets a special surprise :D
This should be interesting...
How many you got going? Doesnt seem to be much interest from the public forum anyway. I just thought everyone would be dynoing to go.
Hi All,
A great turnout for the day, plently of cars and some new faces too. We had cars on the dyno all day from 10:30am through to 4pm so certainly no shortage of cars. Plently of nice food and some good drinks. For those that missed out it was a good chance to run your car and check out how it compares to others and to also ask some of the finer tuners in melbourne for advice and suggestions.
All in all a great day and a fine SAU bbq. Thanks to all of those for their efforts in this event. Pics to follow soon as I left my datacable for my camera at home.
Thanks guys
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
