Got a R33 skyline and got a odd head deck in it which fills the whole gap that the normal cd player & radio came in, in the skyline.
Anyway... not liking the headdeck that came with the skyline due to a few reasons, mostly because its damm hard to figure out how to use it without any manuals.
So... what I'm thinking is either
a) get a normal size mp3 head deck
or
B) get a dvd head deck player & a 7" screen mounted above the dvd player to fill the whole game.
Just wondering what would be best to do?
Also if I was to get the mp3 head deck, how would I forfill the gap underneath it? Where would I get one of those small bucket place holding things that people put in theirs if they get the small face plate head deck things?
Thanks!
https://www.sau.com.au/forums/topic/89926-changing-the-headdeck/
Satanic, I have seen them... if it's the ones I've seen then they are two units, one with a no-name screen, that connects up to a no-name head unit that plays DVDs, CD,s etc...
I was looking to go down this path, but how often do you carry DVD's in the car and actually watch them? Meh! I bought an mp3 player, rewired the whole rig, and got an aftermarket DIN slot for my smokes and mobile. (same as my old car had).
To be honest, the aftermarket DIN pockets don't fit too nicely and I had to do some dremel-modding to make it screw in nicely. I'd be more inclined in the future to try getting a genuine pocket from Nissan that apparently is used on Pulsars etc.
That, or buy the pocket that you had for sale, Stan! I kinda wish I had seen it first... it looks like it'd fill a DIN hole perfectly!
Well it's actually just ON HOLD atm... although I don't think Prank will fall through :P WILL YOU NOW PRANK :P
And yes it is/was a perfect fit... even better than the replacement Sony I got ;)
Edited by satanic
Well, when I installed my head deck I put a cd holder instead of a pocket. It wasn't an exact fit so on the top I put some filler foam I found lying around my dad's workbench.
Just a thought for you.
How goes the search? you decided yet what you want to do with the stereo install?
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
