  • 2 months later...
  • Replies 45
Posted Images
  • 6 months later...
U blokes are ledgends i also had the pleasure of destroying my coin box for a turbo timer... im looking at the fuse listing goin... ah its all in Japanese anyway *GRIND NOISE*... >_<
Thanks a bunch
  • 10 months later...
can anyone elaborate on what "electronic accesiories" is ? like anyone had it blow and been linked to something not working? just wondering aye
Yep, on series 2 auto at least, bottom-right "electronic parts" fuse runs the central locking & I think the key remote receiver. It blew when I shorted one of the central locking power connections when I was installing my alarm/immobiliser. Twice.
  • 3 months later...
Hey guys, first post, not even sure if i'm doing this right!!! Anyway, just recently bought an m35 250t rx four in white pearl. So far im loving it. Just a question to see if anyone knows where the headlights and/or driving lights fuses are located? My driving lights were working when i picked the car up but now theyre not. Thought id start with the fuses. :D
you mean the yellow foggies in teh front bar? I think they are disabled as part of compliance, but you said it worked when you picked the car up?
Hey guys, first post, not even sure if i'm doing this right!!! Anyway, just recently bought an m35 250t rx four in white pearl. So far im loving it. Just a question to see if anyone knows where the headlights and/or driving lights fuses are located? My driving lights were working when i picked the car up but now theyre not. Thought id start with the fuses. :wave:
  • 2 months later...
  • 4 months later...
You are all ruining my thoughts. And I love you for doing it.
I have a sticker on the coinbox, with a different setup. I tried to pull the 4wd fuse after i've read i can do it for a short time, but nothing happened. I wondered if i had got it wrong and it wasn't posible, but i must have a sticker for some other car...
Thank you so much for sharing all the information in this forum. :D
DONT PULL THE 4WD FUSE and drive mate!!!
It will fry clutch parks after short period of time!
Okey? :banana:
What i've found when e read about it it was good for short drives, but not a day at the dyno.
I thrust you in the same time i get curiuos how nissan could build a car that destroys the clutch if i fuse breaks.
But i will take your advice and not pull it out. :P
  • 2 years later...
  • 2 years later...
posted before but here it is again, S2 fuse box translation.
I know this is an old post, but I've just had the lights behind my speedo, tacho, and dials in the central column go dark in my s2 stagea (ie the cluster lights).. Not so good when you are driving at night as it makes seeing your speed dificult..
Looking at the fuse translations I checked 'meter', 'electrical parts' x 2, and room lamp (just in case) and they were all fine (pulled them out and checked with the meter..) - does anyone have any idea what other fuse I should check or any other thoughts on what the problem might be??
Ian
Edited by ian
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
