  • 2 months later...
  • Replies 45
Posted Images
  • 6 months later...
U blokes are ledgends i also had the pleasure of destroying my coin box for a turbo timer... im looking at the fuse listing goin... ah its all in Japanese anyway *GRIND NOISE*... >_<
Thanks a bunch
  • 10 months later...
can anyone elaborate on what "electronic accesiories" is ? like anyone had it blow and been linked to something not working? just wondering aye
Yep, on series 2 auto at least, bottom-right "electronic parts" fuse runs the central locking & I think the key remote receiver. It blew when I shorted one of the central locking power connections when I was installing my alarm/immobiliser. Twice.
  • 3 months later...
Hey guys, first post, not even sure if i'm doing this right!!! Anyway, just recently bought an m35 250t rx four in white pearl. So far im loving it. Just a question to see if anyone knows where the headlights and/or driving lights fuses are located? My driving lights were working when i picked the car up but now theyre not. Thought id start with the fuses. :D
you mean the yellow foggies in teh front bar? I think they are disabled as part of compliance, but you said it worked when you picked the car up?
Hey guys, first post, not even sure if i'm doing this right!!! Anyway, just recently bought an m35 250t rx four in white pearl. So far im loving it. Just a question to see if anyone knows where the headlights and/or driving lights fuses are located? My driving lights were working when i picked the car up but now theyre not. Thought id start with the fuses. :wave:
  • 2 months later...
  • 4 months later...
You are all ruining my thoughts. And I love you for doing it.
I have a sticker on the coinbox, with a different setup. I tried to pull the 4wd fuse after i've read i can do it for a short time, but nothing happened. I wondered if i had got it wrong and it wasn't posible, but i must have a sticker for some other car...
Thank you so much for sharing all the information in this forum. :D
DONT PULL THE 4WD FUSE and drive mate!!!
It will fry clutch parks after short period of time!
Okey? :banana:
What i've found when e read about it it was good for short drives, but not a day at the dyno.
I thrust you in the same time i get curiuos how nissan could build a car that destroys the clutch if i fuse breaks.
But i will take your advice and not pull it out. :P
  • 2 years later...
  • 2 years later...
posted before but here it is again, S2 fuse box translation.
I know this is an old post, but I've just had the lights behind my speedo, tacho, and dials in the central column go dark in my s2 stagea (ie the cluster lights).. Not so good when you are driving at night as it makes seeing your speed dificult..
Looking at the fuse translations I checked 'meter', 'electrical parts' x 2, and room lamp (just in case) and they were all fine (pulled them out and checked with the meter..) - does anyone have any idea what other fuse I should check or any other thoughts on what the problem might be??
Ian
Edited by ian
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
