yeah, thats what i was thinking, there could be a problem with the map in it..
No doubt your tune is saved so why dont you just try putting another base tune on it to get it fired up???
UPDATES FOR ME: 1/4 window fitted thanks to Matt @ Highway Crash Repairs, new oil cooler core purchased (thanks JUST JAP) and on its way so all thats left is a Z32, install new SABER gauges (thanks to FLYNN PERFORMANCE) and coils (thanks BENSON MOTORSPORTS) and its ready for a tune :P
Oh and new set of Proxes 4's ordered (thanks to Hamish @ REVOLUTION)
Fresh(er) RB20DET (from R32) fitted, GT-R injectors, AFM and Nistune...injector o-rings leaking so back apart to fix those, blanked off knackered cold start regulator. Need to get wideband on to start tuning it as currently it just idles at about 2500rpm and dies when you touch the throttle.
Also chucked in 3" split dump/front pipe, all redtop covers on silvertop RB20, ISC 10/8kg S13 coilovers, 17x9/17x10 meisters and waiting on my rotors to be redrilled so I can chuck my R33 4 pots on the front. 11 row greddy-copy oil cooler kit to go on.
Still need a shifter as mine went walkabout while the car was stored at a certain workshop which is now defunct...
Also yet to order front mount and new front bar, but will be soon.
33 - had a flat yesterday and who knows where the locking key has gone... vice grips to the rescue!
rx7 - the dust is growing thicker by the day, but paul is now back from japan so hopefully we'll have an engine ready for it soon
lancer - coming together, just need a clutch, some more white paint and time to keep swapping parts from shell to shell!
Waiting on a brake seal kit and a clutch line to get my car regoed.
Something else is bound to go wrong as everything that could go wrong has gone wrong, but its practically a new car now as ive replaced nearly every nut and bolt in it!
Picked up the 32 this morning after getting the 1/4 window fitted. It will do for now but cant say im impressed with the finished job so once the car is tuned it will be going somewhere else to be done again.
I just pray that it doesn't break :D
well finaly got my hands on hold of a R34 PFC and some split fires, getting 040 on pay day as well, on the look for a boost controller duel stage or EBC, then to hobart for tune and finally get the body kit fitted :huh:
I had Sam (Dr Drift) tune my car on his dyno the week before power cruise.
So I'm now running a fully tuned PowerFC with optional boost controller, Z32, Splitfire Coil packs, 550cc Injectors and a HKS GT-RS :D Cant wait for the weather to get cool for some more ponies!
I'm also running no front bar due to an incident with a guard rail in the wet :D:down:
Edited by Az_StrYdeR
Ended up pulling 244rwkw's flat, and it was pretty hot that day too.
Nice an responsive, very happy with it. Think I'm going to need new shoes soon though :) love's 4k
Jase, got a link to this ECU?? I read a bit about it in the Stag section but still vague on it. And is yours a S1 or S2? We have $2.7k coming from Uncle Kev soon..... :blush: Might be an option for, ummmm, fuel economy? :D
Cheers, Greg.
Looks great Ian, i hope you keep this one for a little while and enjoy :(
My car is ready/waiting to be tuned so hopefully i can sell it soon so i can start my new project....
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
    • Welcome!  Can't go wrong with a Stag.
    • Looks good. Nice height.
    • Hey all, a little help from the Stagea hive mind plz.. I'm days away from buying either a 2002 Stagea 250tRS AR-X Four, premium leather, power seats and all the old switches etc that go with it, or a 2002 Stagea 250tRS VR-X Four AERO, pov pack, cloth seats etc, with coil overs, sports zorst, comes with original zorst and suspension and parts. (I think I've got the models right?) Both are VQ25DET, have 160000kms, both straight no rust both with $2000+ in recent servicing receipts, both ride on aftermarket 18" rims. The Aero has a replaced turbo as well. I like the cool factor of the Aero car but the AR-X has never been modified. Neither have been driven hardly at all in the last 5 years. Any thoughts on which one or does it come down to personal preference? davemoto
