From what I can gather, Andy was his usual self and didn't really say much.
He did say that the software was pretty much just another version of the same old stuff.
He did have issues and had to use my laptop instead of his own as there is a very specific sequence that must be followed when installing everything for the first time. If its not done correctly then the wrong USB drivers are installed and the laptop wont connect to the ECU and they are very difficult to uninstall.
Jump on the ViPec website and check out the features for yourself. That and the support offered through the ViPec forums was enough to convince me to go that way.
Thanks for the feedback...
Andy is a pretty serious kind of guy. I seemed to get along with him great. You do really need to have your car sorted before you take it to him, he's just too busiy to stuff around with the crappy little things.
I've spoken to Ray a couple of times now... he's very helpfull and seems really genuine about helping you out. ViPec is at the top of my list, especially as I have a ruzic EM pro II on the way.
From what I've seen, the software is very similar to Link ecu's.
Cheers
Justin
Cheers
Justin
If by similar you mean identical in every way, bar the sticker over the top of the link logo on the circuit board, and a price premium... you are correct.
Edited by sav man
Whats that i hear......
you can buy a link cheaper and they are the same?????
No shit!!!!
Thats probably because they are basically the same thing. :)
There's a whole thread on this... http://www.skylinesaustralia.com/forums/Pl...l&hl=vi+pec
Plus after talking to a few industry guys, I believe the r&d and hardware that has been put into this product justifies the cost... Plus it's a plug-in.
Alot of ecu choice ends up being influenced by your tuners prefrence. Just wondering what Kutzie thought of it.
Cheers
Justin
Cheers
Justin
Haha yep, thats been said before. There's ALOT more capable ECU's out there than capable tuners.
Edited by Mr. Untouchable
Just bought a fire extinguisher for my r33, where should i mount it for track days? I'll be keeping my rear seat in and my front passenger seat need to be able to move forwards for people to get in the back.
Cheers
Brad
Cheers
Brad
mines mounted on a bracket on the passenger seats mount points, what i plan to do is make a bracket extending off the front passenger seat mounts so it sits in front of the passenger seat :rofl: just gotta not be lazy and do it lol
Mine is mounted behind the drivers seat in the footwell.
Put some nutserts through the panel below the rear seat cushion and mounted it there. That way if people sit in the back its behind their feet anyway but still easily accessible if ever needed.
Just gotta be careful where the holes are drilled as there are a lot of looms running up and over in the same spot.
Will try and get a picture of it later tonight and post up.
Edited by SSHatch
Took me all of 30mins that night in the garage where it wasnt wet and f*kn muddy.
That really pissed me off. At least if I had broke something I wouldnt have been able to fix it, but being just a hose come off and not being able to put it back on and as such missing out on the best part of the day.... :rofl:
Bought a new power window mechanism for my R33 drivers side a few weeks back, got it installed and it failed miserably (fine until it had weight on it going up, then just grinded horribly). Luckily managed to get the existing one un-jammed so it's good for a bit, but sent the replacement back and got another second hand part, just went to install it today and it has the exact same problem as the last one :nyaanyaa: The crappy thing is I'm not even sure it's a different part, the markings on the mechanism seem veeerry familiar.
Other than that she's going beautifully, took her in for a service/check up a few weeks back and no real problems found, had her for over a year now and have had next to no problems (which I wasn't expecting at all).
Actually, speaking of problems... Had some Bstrd key the bonnet of my car a couple of months back, does anyone happen know of someone who can do a cheap (but decent) patch up of the paint on the front? She's standard factory white so I doubt finding the colour would be difficult.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
