Ah ok then, the fpr has a gauge if that's what you mean I think it sits on 4 -5 psi I don't know about them tho
they shouldnt be tampered with unless you have a wide band oxy sensor ect
But the base fuel pressure should be around 3.5 bar. and rise under load.
if its 4 or 5 bar (big difference) than its probably squirting 10-20% more fuel into the car.
you have 2 options. replace the reg with the stock unit or wind the pressure back. do this at your own risk as you also have the potentual to lean the motor out by doing this as well. if it was my car id have a play with it and see.
Hey autumn I have a safc2 for sale, 250 delivered as new condition with all wiring etc. This will allow you to tune your fuelling and run a z32.
Also if your relying on a drift brand air fuel ratio gauge to tell you what the cars tune is like, your headed in the wrong direction. One of those gauges won't tell you much at all, you need a proper wideband a/f monitor.
I've got some interesting problems with my R33.
Problem #1 When I brake the pedal goes straight to the floor, then upon having a 2nd stab at the brakes it'll be fine, good feel and pulls up fine. Giving the brake a left foot chicken tap before braking doesn't seem to help.
Problem #2 with the brakes, when I'm doing a burn out and having the left foot on the brake the pedal get really hard and pushes my foot off the brake and eventually the brakes stop working and the car will just go forward. (obviously doesn't want to do skids lol)
Problem #3 Steering is really really heavy sometimes, all morning at drift practice it was f**king and the car didn't self steer at all, not when sliding, not when transitioning, not when crusing around the corners in the no drift part of the track, you turn, the wheel will stay at that angle until you change it, and it's so heavy only the hulk can steer it. This problem randomly went away in the afternoon of the drift festival but came back when unloading the car off the trailer. Car is a NA conversion so it doesn't have HICAS.
Suggestions?
I'm thinking the braking problems could be because the NA Brake booster doesn't like being turboed?
probabaly silly question, but have you checked and bled the powersteering fluid?
Checked yes, Bled no, that's this weekends job.
that sounds just like my brake problem.
you can pump them up to hard. Then as soon as you take your foot off its soft as shit.
If I pump mine up it'll stay pumped.
Yours sounds like leaky lines. Had that problem in old Suby wagon.
ive bled them but still no go, did it again yesterday, might look into some braided lines or something :)
Are you doing it right? I remember trying to do it on my old motorbike and constantly f**king it up but not knowing any better.
whats the right way?
i do it like this
pump the pedal till its hard then get who ever to open the caliper nipple then they close the nipple once the pedal has hit the floor
is that the right way lol
Edited by Autumn33
Suggestions?
1# bleed your brakes
2# you need to have a 1 way valve between the booster, and the plenum. You either don't have one, or it's stuffed (pretty commen), one way valve will fix your problems. But remeber, the booster can only hold so much vacume, so depending on the lenth of time your on the brakes, your pedal will get harder.
3# could be your rack, and/or pump.
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
