Ah ok then, the fpr has a gauge if that's what you mean I think it sits on 4 -5 psi I don't know about them tho
they shouldnt be tampered with unless you have a wide band oxy sensor ect
But the base fuel pressure should be around 3.5 bar. and rise under load.
if its 4 or 5 bar (big difference) than its probably squirting 10-20% more fuel into the car.
you have 2 options. replace the reg with the stock unit or wind the pressure back. do this at your own risk as you also have the potentual to lean the motor out by doing this as well. if it was my car id have a play with it and see.
Hey autumn I have a safc2 for sale, 250 delivered as new condition with all wiring etc. This will allow you to tune your fuelling and run a z32.
Also if your relying on a drift brand air fuel ratio gauge to tell you what the cars tune is like, your headed in the wrong direction. One of those gauges won't tell you much at all, you need a proper wideband a/f monitor.
I've got some interesting problems with my R33.
Problem #1 When I brake the pedal goes straight to the floor, then upon having a 2nd stab at the brakes it'll be fine, good feel and pulls up fine. Giving the brake a left foot chicken tap before braking doesn't seem to help.
Problem #2 with the brakes, when I'm doing a burn out and having the left foot on the brake the pedal get really hard and pushes my foot off the brake and eventually the brakes stop working and the car will just go forward. (obviously doesn't want to do skids lol)
Problem #3 Steering is really really heavy sometimes, all morning at drift practice it was f**king and the car didn't self steer at all, not when sliding, not when transitioning, not when crusing around the corners in the no drift part of the track, you turn, the wheel will stay at that angle until you change it, and it's so heavy only the hulk can steer it. This problem randomly went away in the afternoon of the drift festival but came back when unloading the car off the trailer. Car is a NA conversion so it doesn't have HICAS.
Suggestions?
I'm thinking the braking problems could be because the NA Brake booster doesn't like being turboed?
probabaly silly question, but have you checked and bled the powersteering fluid?
Checked yes, Bled no, that's this weekends job.
that sounds just like my brake problem.
you can pump them up to hard. Then as soon as you take your foot off its soft as shit.
If I pump mine up it'll stay pumped.
Yours sounds like leaky lines. Had that problem in old Suby wagon.
ive bled them but still no go, did it again yesterday, might look into some braided lines or something :)
Are you doing it right? I remember trying to do it on my old motorbike and constantly f**king it up but not knowing any better.
whats the right way?
i do it like this
pump the pedal till its hard then get who ever to open the caliper nipple then they close the nipple once the pedal has hit the floor
is that the right way lol
Edited by Autumn33
Suggestions?
1# bleed your brakes
2# you need to have a 1 way valve between the booster, and the plenum. You either don't have one, or it's stuffed (pretty commen), one way valve will fix your problems. But remeber, the booster can only hold so much vacume, so depending on the lenth of time your on the brakes, your pedal will get harder.
3# could be your rack, and/or pump.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
