i got that HD go pro too, good quality camera, had misplaced the case and mounts for it when i lent it to a mate last few track days though haha but have it all back now. got external mounts and rollcage mounts. i usually record it in 720p @ 60frames, best quality/ smoothness setting around for that cam.
Have uploaded several vids to youtube with some recordings of it.
took my car to a club day at symmons yesterday
not sure if these will embed. just some average quality from my mates steady hand haha
if you havent seen my build thread take a look.
http://www.skylinesaustralia.com/forums/topic/308918-damos-r32-gts-r-on-going-project-fun-car-history-and-use-full-info/page__st__220
:closedeyes: OK!!
so i was going about it the wrong way!! so i went in and had a big chat this morning ..
now we are going too
install turbo kit ..
do the timeing belt as its never been done ..
engine flush and some new fluids .
have a look at the fuel pump the guy i brought it off said it was a gtr 1 so if its true that will be untuched
ill have enuf money left over for the vipec ecu install and tune .
depending on $ after that injectours !
just a quick thanx to all the reason i come on here is to get some kind of guide on the best parts to redo..
engine will now remain un opend..untill maybe oneday it fails ! !
Edited by Addicted2BoostR34
why the vipec?
a lot of $$$ if its only going to be mildly modded
nistune will support new afm, injectors, raised rev limit, remove speed cut and i think you can keep tcs
also looks like knock maps will be tunable soon (pfc doesn't have this feature apparently)
about $1k tuned and fitted!
why the vipec?
a lot of $$ if its only going to be mildly modded
It's true, NisTune is pretty win.
But any ECU is only as good as it's tuner, so what ever your tuner is most comfortable with really.
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
