Might have to invest in one myself :whistling: , speaking of , i went and got my 34 outta storage tonight :woot: , i'm not sure yet what i'm gunna do with it yet , i'm trying to talk myself out of putting a kinugawana (spelling?) t67 copy on it with support :nuke:
I Just bought my Nistune for my 32 for $580 shipped to my door with everything i need to do all the tuning myself, hard to go past them for a simple plug-in option.
Yeah that seems to be the cheapest way to do it. They're so friggin easy to tune too, I had a look at the software and it looks pretty friendly. Plus if you've got a wideband with an output they can auto tune off that! Then once you've got the AFRs down pat you can wind some timing in till she pings pirate.gif Then back it off a little.
Definitely don't do that.... whistling.gif You better have a car out at the next SAU track day, more than 2 months away so no excuses!
well short story short i bought the 34 that used to park out the front of mykonos in town , it needs some love which i shall give it , has a hideous bomex bodykit (and stickers) which i'm taking off in favor of a altia (nismo) bodykit which i've already purchased along with some trim bits (some tool painted the center console purple :sick: ) , it needs shockies and i'm onto some bilsteins from the old sydneykid packages and i'm up in the air whether to just get it tuned with std turbo or get it highflowed with aim of 250rwk or go 3076 or t67 for ~300rwk :ph34r: , but i can't start buying parts 'till i make my mind up :blush: . i'll put some pics up as soon as i take some :cheers:
What is your project ben??
34 nice pick !! :worship:
how much was that if you don't mind me asking?
also, i'd go see brad at boost for a nistune
pretty sure they will support up to about 500hp (don't know exactly) but it will support bigger injectors, bigger afm, and lots of stuff (plus they keep being able to unlock more and more features with every new firmware update)
rocker covers started around (+sand blast) 80$ then it all changes with more parts isame colour or diff and if they will need a light blast first but ill ge going back later on for some bits n pcs.
Well for my latest project Im still chasing a S13 steering rack and power steering pump and then continue on fabrication and body work.
Might have you under my belt. Let me have a look over weekend. I have quite abit of S13 gear still :thumbsup:
Edited by TJHill
i dont think they do a plug in nistune for a 34 ?? i have hurd i need to get a 300zx ecu wired in and the chiped that to suit the 34 ?? or is it bull shit ?? know of any1 who has dont it for a 34>?>
you have heard wrong
r34 ecu is nistuneable, r33 is the one that is gay
I had a Nistune board in my R34. You buy a Nistune daughter board then you need to get the the factory daughter board unsoldered and the Nistune board soldered in.
I still have the software some where on one of my laptops :blush:
Edited by Wogboy
Just wanted to thank all my mates who are helping me out with the difficult times, keep me grinning at the worst times! Cant thank them enough, HTS Garage - NW, VIC, And Hobart Divisions, Drifting Tas and everyone else!
And a big thanks to my friends who wrote this for me. The cars at the bottom looked 6months of work better than that when they died :(
http://www.wreckem.com.au/the-dave-dennis-dealio-help-a-brosef-out
Edited by Dave.TAS
http://www.wreckem.c...lp-a-brosef-out
We are all feeling for you man and we are all here to help in any way we can. Personally I had never heard of that site but everything written is 100% true and just goes to show how top a bloke you are!
I will be sure to share the link on facey :thumbsup:
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
