my remsa pads just arrived from gslrallysport :)
i bought fronts for the stagea (r34 4 pots) and fronts for the corolla (probably overkill really)
keen to see how they are compared to the current pads, just wondering if i should machine the rotors first
QFM pads are best bang for buck pads out bar none. Aus made, and they rock. I run A1RM pads on my car and they are bloody awesome.
and yes, machine away. a fluid flush is always a healthy option too.
these pads sit between the hpx and ar1m aparently, gsl rallysport are phasing out the hpx's apparently because these are supposed to be better for only $10 more ($89/set)
so tempted to put them in tmrw, but i don't want to bed them in twice and it could be a while before i have a spare car again (corolla is up in the air with about half way through a clutch change atm)
little update got my ecu back hello nistune :)
also .. im lookn at getting my frount bar painted and fitted befor i do anything more i F!@#en hate driveing around with it off looks bogan :domokun:
so whats a good place around L'ton to get it painted and fitted @ a good quality for $$$ cheers i looked at micra ?? i just dont know at all pinch.gif
Finally finished spark plugs! Old plugs were gapped to like 1.4mm! Then took it for a Razzle dazzle on some gravel around sandfly. Seems to have a little more poke off the bottom now which is nice. Missing seems to have stopped too :) true test will be tomorrow though
finns body works near the old coats paintens building. they paint all my mates cars and never a complaint.
so nistune arent super fast with there service then?
pic of 34 from back when i was putting it back together :thumbsup:
Looks good Toff...
Sooooo envious- hoist!!! I just spent all afternoon on my back pulling and reinstalling a gearbox in the gts-t. What a pain in the ... well everything!
cheers na nistune where good i wasnt fussed how long it took so i posted it to confidyne and they sent it away with there one i havent been home to check my mail >.<
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
