picked up my wheels today, just had a chance to test fit them/see how much guard work is needed, but i need to get some longer wheel nuts first.
Here some crappy pics ( the car is still on the jackstands & wheels only sitting on by a nut each )
will post up better pics once its all sorted
post-71390-0-55420300-1341994587_thumb.jpg post-71390-0-99911200-1341994608_thumb.jpg
Edited by Autumn33
Its still on the jackstands at the moment so pics are quite aids, it will be on the ground later today/tonight so i will post up some better pics then.
but because you asked here you go :)
post-71390-0-91050800-1342154290_thumb.jpg post-71390-0-60362600-1342154398_thumb.jpgpost-71390-0-99797900-1342154556_thumb.jpg ( abit dirty they need a good clean/polish)
Edited by Autumn33
Just got it off the jack stands :) Im thinking I will get it out of the garage for some better pics over the weekend.
I have around 100mm clearance at the front bar so its just legal hight wise.
Im thinking of buying some universal bolt on flares rather than going down the GTR or wide body route but ill wait and see.
picture time! (excuse the messy garage ahaha)
post-71390-0-93175700-1342164464_thumb.jpgpost-71390-0-38784800-1342164481_thumb.jpgpost-71390-0-67090000-1342164490_thumb.jpgpost-71390-0-81399900-1342164502_thumb.jpgpost-71390-0-83660100-1342164513_thumb.jpg
it's interesting, I'll wait till I see it in the flesh to pass my final judgement. I reckon it'll have some bozoku style bossness about it, which I don't mind :)
While we're on the topic of wheels I got me some Rays SSR2s 18x9.5 +38, they were gold but after today they're matt black :D
I've got some 245\40\18 Dunlop DZ03G M compunds for them to match the 265\35\18 I've got for the rears :D
What are you doing with your d2r's Pete?
Never really posted any updates in here about our car so thought now might be a good time as there is a fair bit happening. First a bit of background info…
My brother Tom and myself purchased the car, a 1993 R32 GTST, in September 2011 from Victoria, it had an RB25DET which wasn’t engineered so we spent a fair bit of time organising that once we got it back, it was on the road on 11/11/2011 (easy date to remember haha), this is how it looked…
We didn’t really do anything worth mentioning, just tidied a few things up, got some new wheels and went to a few track days at Baskerville.
Then we thought we’d enter the drift practice day in May which didn’t end well with the car being written off, I’m sure most of you have seen pictures/videos and I don’t really want to look at them again so won’t post any of that haha.
Luckily it appears to be only structural damage with only minor damage to engine, surprisingly even front end components such as brakes/hubs were not damaged, the chassis seemed to absorb all the impact.
So we started the search for a shell, nearly bought an S13 which would have been a cool project but ended up getting hold of another R32 in June off DanielH (previously owned by Toffy). Now that we’ve started transferring things across I’m kind of glad we went with another R32 as it makes things soo much easier.
The shell was not quite rolling with no interior but it didn’t matter as we could transfer a lot over from our wreck. During my mid-semester break from Uni we got a bit done…we put in our subframe and front end so it’s now properly rolling (don’t worry everything was checked thoroughly for damage before being bolted up!).
Tom also pulled the RB25 out of the wreck and it has been pulled down to do a few oil control mods (external oil drain, restrictors, baffled sump, oil pump drive collar), head has been decked and replaced valve stem seals, crankshaft seals etc. and the oil pump drive collar is currently getting done. Also discovered big end bearings and clutch are pretty close to needing replacement so figured now is a good opportunity, and rear housing is cracked on turbo (thanks to Tobbie for sorting us out with that and few other bits and pieces).
We’re pretty keen to get it done and get back out on the track again and just enjoy it, I imagine we’ll be taking it pretty easy to start with after all the effort we’re putting in. I guess the good thing about paying someone else to do the work is it doesn’t hurt as much when things go wrong (if money isn’t an issue) but unfortunately that isn’t an option for us haha. I might try and post a few updates as things get done if I have time.
So i got a pair of flares today thanks Damo (DJRIFT) so decided to do a quick mock up
post-71390-0-49570600-1342887865_thumb.jpgpost-71390-0-82309900-1342887885_thumb.jpg ( there not sitting 100% were they need to be i needed stronger tape haha )
They just need a small lip piece cut off then they will fit mint
Edited by Autumn33
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
