So much happening! :D Very exciting stuff, I've done a little to mine but I'll post that over in my thread because there is a fair few pics!
Bushy: Really excited to see you're making some awesome progress; Can't wait to see you on the track again!
Brain: Loving the flares, they don't look too bad even in black. Are you going to colour code them?
Young: That is one Sexy 31, love it! Wheels are mad and boss fitment!
That 31 is porn,
Yeah it is a little bit lower then before I think it may be the angle im taking the pics on as well, I have around 100-110mm clearance on the front bar.
I'll take some better pics when i get it out of the garge.
I think I may just keep them black for now, I'm not 100% sure yet
Slight correction to my last post...I meant to say cam seals were replaced, not crankshaft seals hah. Doesn't look like I can edit the post.
Yep, after 20 Mins you're committed!
That thing better get low ^^ . Ok im bored so i shall waffle , blue snotter is very close to rego , just need to pull my finger out and finish off a few small things . After a fail weekend last weekend where i missed out on the charity ride day over mis communication with people , i finally have my other hq ready for the track again and 28 is back in full swing after the issues in Melbourne . How did everyone go last weekend at the track day? Im Devo i didn't make it :(
Doing some wheel bearing moves on the 31
Also need to redo the passenger side front brake hard line flare, anyone know where you get the hard line brake nuts from? and if a supercheap style flare tool can do the correct flare?
few new pics of mine (still in the garage) after getting another pair of flares, should have them on & out of the garage by next week.
this is starting to grow on me. Look forward to seeing it finished for next Sunday....
Yeah im good mate thanks , basically , i ran out of talent . I was playing with tyre pressures and a couple other things with the car and came through the esses too hard , got sideways , the clutch wouldn't dis engage properly and bam! . Only damaged the nose cone and front guard luckily (and bonnet and door) . My bad :s
I'm struggling highly for motivation at the moment.
Also for the first time in about 3 outings I actually jacked my car up to check it and found some epic inner wheel damage from the last prac day. My spotter kept edging me deeper and deeper to turn 1 untill I broke it. Also gave the chassis a good knock from another ripple strip adventure. Otherwise it's all sweet and ready to go for round 3.
I have several aspects to revamp on the. Car but can't seem to get into it. Any one got a way to get yourself motivated?
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
