So much happening! :D Very exciting stuff, I've done a little to mine but I'll post that over in my thread because there is a fair few pics!
Bushy: Really excited to see you're making some awesome progress; Can't wait to see you on the track again!
Brain: Loving the flares, they don't look too bad even in black. Are you going to colour code them?
Young: That is one Sexy 31, love it! Wheels are mad and boss fitment!
That 31 is porn,
Yeah it is a little bit lower then before I think it may be the angle im taking the pics on as well, I have around 100-110mm clearance on the front bar.
I'll take some better pics when i get it out of the garge.
I think I may just keep them black for now, I'm not 100% sure yet
Slight correction to my last post...I meant to say cam seals were replaced, not crankshaft seals hah. Doesn't look like I can edit the post.
Yep, after 20 Mins you're committed!
That thing better get low ^^ . Ok im bored so i shall waffle , blue snotter is very close to rego , just need to pull my finger out and finish off a few small things . After a fail weekend last weekend where i missed out on the charity ride day over mis communication with people , i finally have my other hq ready for the track again and 28 is back in full swing after the issues in Melbourne . How did everyone go last weekend at the track day? Im Devo i didn't make it :(
Doing some wheel bearing moves on the 31
Also need to redo the passenger side front brake hard line flare, anyone know where you get the hard line brake nuts from? and if a supercheap style flare tool can do the correct flare?
few new pics of mine (still in the garage) after getting another pair of flares, should have them on & out of the garage by next week.
this is starting to grow on me. Look forward to seeing it finished for next Sunday....
Yeah im good mate thanks , basically , i ran out of talent . I was playing with tyre pressures and a couple other things with the car and came through the esses too hard , got sideways , the clutch wouldn't dis engage properly and bam! . Only damaged the nose cone and front guard luckily (and bonnet and door) . My bad :s
I'm struggling highly for motivation at the moment.
Also for the first time in about 3 outings I actually jacked my car up to check it and found some epic inner wheel damage from the last prac day. My spotter kept edging me deeper and deeper to turn 1 untill I broke it. Also gave the chassis a good knock from another ripple strip adventure. Otherwise it's all sweet and ready to go for round 3.
I have several aspects to revamp on the. Car but can't seem to get into it. Any one got a way to get yourself motivated?
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
