cheers Frosty. 1990 Ti model with manual conversion, electrics all work, replaced original cut springs and shocks as it was sitting on the ground and the shocks were 100% rooted.
Sure it looked cool being lower.. but not practical as i couldnt even get in and out of my drive way properly.. eg below (got beached maybe once or twice and the cat got hammered, eventually blew a gasket)
Edited by Funz
Well i dont accaly think ive ever posted up my currant project on here so heres a bit of a run down
Of what ive been up to it was a crashed car runing with rb20det i paid $2000 for heres a run down of some of the parts in a very random order or whats on/in car and what i have to go on
Rb25det, kkr430, forward facing plenum, normal fmi and 3 inch exhaust (with proper 3 inch muffler)
Coilovers, rear camber arms, hicas lock bar, caster arms, r33 lcas
Extra lock spacers, longer wheel studs, 52mm radiator, bride seat on low mount rail, 044 and surge tank,
18x9.5 and 18x10 veil side andrew v wheels, toyo r1r on front, r33 front brakes,
Power fc
Dont mind the front bar ive got a gtr copy bar lined up to suit rest of kit
Edited by lawler
  • 3 weeks later...
30, more torque, cheaper. decent turbo setup will just defeat a 20... Plus a 30 is already in there?
this.
find a manual conversion kit.
will end up being around the same price as a 20 swap.
just de pigying my 32 fixing all the faults and legalising it :P
if anyone ever has a problem with oil filling there sparkplug galleys in rb##det because of some dead shit thinking gasket goo will do.. ( n i meen fill like submerge ur spark plugs compleatly)
my method was a shit tone of degreaser shove it right in there and sponge it up with a rag and string it out, keep going til its as cleen as u canon all 6 galleys, and then degreaser and compressed air til nic n cleane and leave it to dry i repeted all the prosess 3 times for all 6 galleys that was enoigth, when i was blowing it out i covered up the bay, exterior and window etc completely only exposing the head of the rb, so yeah dont leave ur head covers unsealed corectly for any drastic amount of time guy$ :P i really made sure it was clean i coukdnt risk and bit going into the bore and seizing it when i change the plugs abd it was just nasty and probly somewhat flamible
Power fc
nice work m8 are u interested in selling the front bar mind u ill probly end up cutting sonething like that down to meet 100mm + off grond probly be trying to get my car 13 cm of ground at front it hitts everything even if i angle it and go supper slow at. 12cm with a busted bar :/
Cheers guys , I've made my mind up , the 30 will stay , with turbo kit , when it blows I'll slap the 20 in :D , I have a flowed 25 turbo , gtr injectors and a z32 laying about I'm sooo tempted to whack on the 30 , I doubt the gearbox will take it for long though lol
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
