another one? :( i think a mate may have one if you haven't got one already,
Yep....had a speedo cable for 2-3 weeks. Time for a few more nights in the shed :unsure:
Edited by TJHill
look forward to seeing this splitter :yes:
haha nothing too fancy mate, going for a bit of a industrial look. I'm actually making up something very simular to Brad sheriff's, and Peter Nunns. except i'm going to run 4 adjustable turnbuckle braces from the front coming down. I'll post up pics when I'm done :ninja:
build mine as im lazy and dont have time? :P ill pay you with a bucket load of... sarcasm and ridicule :P
ohhh sounds like a scam lol. Last fibreglass bar i worked on was Pisko's 350z bar after he stacked it at symmons. I'm still trying to get rid of the glass splinters haha. I'm not a fan but i need a whoop ass splitter, Mr Plow spec and its not going to build itself =)
you going 40ft wing to balance out the car if you build a splitter?
I've got a pair of genuine n1 adjustable cam gears if you don't want shiny hks/trust ones, or cheap and nasty ebays.
Dave 0409 631 092
haha im broke dave, if u have them in another month or so i'll be interested :thumbsup:
Hi guys. Thought I'd post up a few pics of my front bar repair/mod progress. My front bar had a few decent cracks and had a fair size chuck missing on the lower front left hand corner so i went hell for leather with the glass. i chopped the bottom of the bar off level as the bar was lowest at the rear so it would of made the splitter sit up at a nasty angle. I've used ally sheet as the splitter itself. its 700mm deep and protrudes past the bar 5 inchs in the middle and just over 4 at the corners fadding back to inch at the sides. the ally is bolted to the bar in the middle and at the rear corners and i have just test fitted the 4 turnbuckle braces also.
just finished buzzing back the paint on the major surfaces and i have scotched the rest of it and i have put a light dust coat of etch over it as guide coat really, going to rub it down now with 400 ready for 3-4 coats of primer.
not going to be crazy fussy as its more of a prototype, looking forward to getting it on the car and eventually I'll buy a new bar and go again.
I've basically tried to replicate what is on Peter Nunn & Brad Sheriff's R32's.
cheers
Nice job! But for the ground effect to work you need to roll maybe two thirds of it up so that it's basicly like an upside down wing, if you look at V8 super cars you'll know what I mean. That's what I plan to do with mine, when work permits. Just my thoughts :blush:
Thanks wogboy. yes my plan is to tig or bolt two brackets at the back of the splitter and run some straps up around the sway bar with a 10mm thick anti vibration foam stuck to the splitter below the K frame. that way i can pull it up tight and if i run the straps I have here they have clips so they can be quick release should i want to get the bar off easily. I dont really want to mount it solid at the rear but I will if i have to.
looks awesome jack! i think you should make mine :blush:
ohhh I'm all splittered out atm lol.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
