  • Replies 42
Holden are bloody lazy. I loved holden until ford released the XR6 Turbo. Thats when the respect came from. Holden UNTIL TODAY still hasnt created a rival turbo car to compete against the XR6T.
Rumour has the VE Commodore (replacement for the current VZ) will have the option of a twin turbo V6, similar to that used in the Torana concept car.
another huge ford fan here. not bad, although, i think ford, in the current automotive climate (ie, coupes, turbo's and drivability being issues ppl look at nowaday's rather than pure cubic inches), would do well to release a cutdown 2 door, based on the falcon chassis (just like the monaro from holden), with the 4L turbo 6, and awd.
did someone say Ford GTR? :)
I thought waaaaay back when they announced the Territory that by the time the BF update came around they would be making all wheel drive falcons. I am really suprised that they haven't done it. Even though the AWD system is Auto only, a 6 speed automatic AWD falcon with Turbo 6 or V8 power would be incredible. They should wack a blower on the V8 while they're at it too - it's just a matter of dipping into the Ford parts bin,
I think they took note of how badly the AWD Magna flopped.
Very similiar to the AU's ugly front end, they quickly changed that, what do Magna go and do.. Make model after model based on the same fugly headlights.
Edited by Cubes
F*CK the focus, i want my Esky!!
Im seriously thinking about going over there to live for a year so i can have one :(
If someone offered me one of these OR an R34 GTR, i would dead set not know which one to pick :(
B)
I've always had a leaning towards Holdens but after the Ford Turbo range came out I converted :P
Btw, whats a better overall package in terms of power and handling?
Ford Typhoon or the Subaru Liberty GT?
Both are very yummy and if i had to get a family car it would be one of those.
If I had to buy a big sedan, I'd get an XR6T and do my own tweaks to it.
But then, if I was buying a sedan my priorities probably wouldn't be to get a very quick car, and I'd take the build quality, interior trim, and fuel efficiency of an Accord Euro or Liberty GT over the superior pace of a Falcon or Commodore.
absolutely! one of the best Australian built car on the market! a mate did chip, full exhaust, air and fmic to his xr6 turbo, bang! 296rwkw! all for $4.5k! beat that
I love to see intelligent open minded conversation on our forums
i think hes just trying to turn this thread into another potentially meaningless debate lucky this is not an holden or ford forum
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
