Im sick of 3000rpm at 100kmh..... in 5th gear...
has anyone changed their ratios in the box? or anything else that will solve the high revving problem.....
at the moment the car uses more petrol on the highway then in the city.... lucky to get 200km from half a tank!!!!!!!!
soooooooo sick of it!
Ed
https://www.sau.com.au/forums/topic/91554-gearbox-ratio-change/
lol..
Imagine the poor souls with their R32's running a RB30DET's.
I'm always reaching for 6th.
The tacho is actually a little wrong, the pfc h/c states ~2800rpm for 100km/h. It is still too high though.
I will be dropping a S13 3.9:1 diff in mine, there is also available a S13 ~3.7:1. Really depends what you want, I want to keep the 'sports' feel so 3.9:1 is the highest ratio I will go.
The VLT has a longer 5th gear, throw a vlt g/box in to the r32.
Edited by Cubes
100 kph is 2,750 rpm with a 4.363 diff (R32GTST) a 0.759 5th gear and 245/45/17 tyres.
100 kph is 2,600 rpm with a 4.1 diff (R32GTR) a 0.759 5th gear and 245/45/17 tyres.
100 kph is 2,500 rpm with a 3.9 diff (S13) a 0.759 5th gear and 245/45/17 tyres.
100 kph is 2,400 rpm with a 3.7 diff (S13) a 0.759 5th gear and 245/45/17 tyres.
As you can see there is not much difference, I suspect that you will improve the fuel economy far more by spending the money (that a dif change would cost) on some tuning.
;) cheers :)
check your 02 sensor as well, nuturious for angry fuel economy. if i do all highway driving i get over 400k's to a full tank and thats sitting on 100km's in 5th gear so it sounds like you arent going into closed loop mode or your sensor is dead
I've just used my trusty gearcalc program.
@100km/h in 5th.
225 x 50 x 16" tyres.
4.36:1 Diff - 2782rpm
4.11:1 Diff - 2621rpm
3.9:1 Diff - 2487rpm
3.7:1 Diff - 2360rpm
So for myself running a 3.9:1 a drop of 300rpm, the diff needs replacing anyhow.
The biggest benifit will be picking up approx 9km/h in second gear and ~13km/h in third. Especially with the rb30det this will be handy. :)
Should I go the 3.7 that will be ~14km/h in second and ~20km/h in third I pick up.
@100km/h in 5th.
The biggest benifit will be picking up approx 9km/h in second gear and ~13km/h in third. Especially with the rb30det this will be handy. :P
Hi Cubes , how do the numbers run for the manual VLT ? I think the final drive was 3.45:1 but it used a 3.6 1st wide ratio box and 205/60/15 ? Also how does the weight stack up compared to a typical RB30DET R32 2wd ?
Cheers A .
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
